Re: Electric fan setups.....Pics? Pros/Cons?
[Re: StealthWedge67]
#3017492
02/21/22 09:03 PM
02/21/22 09:03 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
OP,
At minimum, especially if it’s a street/strip car, run a shroud with fan, or even a small shroud with electric SPAL fan. You could even try pusher or puller arrangement with an electric SPAL fan if you have the room. Here’s my setup.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: wkroncke17]
#3017552
02/21/22 11:13 PM
02/21/22 11:13 PM
Posts: 4,209 New York
polyspheric
New York
Without a shroud, the fan blades are simply pumping hot air in the engine bay around. Above 35, the forward motion moves more air than a fan... if the grill opening leads directly to the core.
Boffin Emeritus
[Re: polyspheric]
#3017560
02/21/22 11:46 PM
02/21/22 11:46 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
I bought an ebay aluminum radiator because anything "good" (as far as radiators) was over 2 months out projected delivery. With that I used SPAL 30102130 fans.
[Re: wkroncke17]
#3017599
02/22/22 07:20 AM
02/22/22 07:20 AM
Posts: 2,924 A shed in England
Tig
A shed in England
Not the best pic but the only one I've got. We use a pair of Spal pushers with individual temp controllers as we didn't have much room for pullers. Works well, we've had this set up on 2 combo's 572 and 655 with no issues. At idle, if you overide the controllers, you can watch the temp fall on the gauge.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: dvw]
#3017676
02/22/22 01:11 PM
02/22/22 01:11 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
Hard to go wrong with s Spal fan and shroud. OE part on a lot of exotic cars. Defintely get one that is a shroud. They offer many different ones. Try to cover as much as the core as possible. I run them on my street car and they work like a champ here in the desert.
[Re: dvw]
#3017735
02/22/22 02:55 PM
02/22/22 02:55 PM
Posts: 19,470 north of coder
moparx
The dual fans out of a late Challenger/Charger adapt pretty easily. Doug i prefer to integrate factory fans and their shrouds whenever possible. i believe they pull WAY more air than the aftermarket ones, and are much more reliable as well. however, they do [as a rule] pull a bunch of amps at start up, so relays, large wire, and updated alternator/regulator are usually required when using them. still, i feel the added effort of the install and minuscule weight gain offset the gains in cooling performance.
[Re: wkroncke17]
#3017744
02/22/22 03:13 PM
02/22/22 03:13 PM
polyspheric
New York
Find and seal any grill, light, signal etc. openings in the nose that admit air to the engine bay. All incoming air must go through the core.
Delay box is hot with the starter, no power to the fans for (how many) seconds to avoid high amp draw on starting.
Boffin Emeritus
[Re: wkroncke17]
#3019325
02/27/22 10:26 AM
02/27/22 10:26 AM
Thumperdart
State of confusion
You need a shroud number one, to not get parts amputated by those sharp blades when they DO come apart and to control the air entering the radiator...
[Re: DrCharles]
#3022205
03/09/22 06:02 AM
03/09/22 06:02 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The ford Contour fans are decent and should work if you don't have A/C. They are also inexpensive compared to a Spall. I bought a new Contour fan assembly for around $100 https://www.summitracing.com/parts/fss-75282/make/ford/model/contourand the special plug ends that goto the fans: https://www.summitracing.com/parts/...JdANaWJiuIrB1IW9S9j6TiPE-PRoC7AAQAvD_BwEI used the older version of the Dakota Digital Fan controller. The new one has blue tooth. https://www.summitracing.com/parts/dak-pac2800btI wired up the high/low speed resistor that is in the fan shroud, but I normally just ran them at high speed. I would just wire each fan to a relay, and not use the low speed resistor which will save you from buying an extra connector for the resistor. After I added A/C I needed more cooling, so used two 13" Be Cool fans (the Be Cool fans are Spall fans, and were on sale when I bought them.) on a Griffin 26" radiator. The high flow units are thicker, so if you go that direction make sure you have the radiator to engine clearance. The 13" 1,777 cfm versions are 3.45" and cost $165 each.
[Re: 451Mopar]
#3022278
03/09/22 11:45 AM
03/09/22 11:45 AM
Posts: 4,569 Motor City
6PKRTSE
Motor City
I have a custom made radiator with dual Derrale fans.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: moparx]
#3022287
03/09/22 12:01 PM
03/09/22 12:01 PM
Posts: 12,395 Taxes & Virus's R-US, NY
Dragula
Standard Universal BeCool and their fans & shroud... Cons...Stops working when you overload the wiring! Use good relay's and good wiring if you go this route. The newer fans pull a ton of juice and will find the week spot in your electrical spaghetti mess if you cheeped out anywhere. https://proshop.summitracing.com/parts/bci-62087
[Re: Dragula]
#3022310
03/09/22 01:09 PM
03/09/22 01:09 PM
Posts: 11,608 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
You would be surprised at how small of a radiator you can get away with IF you get enough air through it.
Pusher fans suck, figuratively speaking. They are in their own way of moving the air.
This is a deal we did. It's a tight fit in a little truck. Big aluminum radiator. Had a single big pusher on it and the thing would not cool at all. I got a shroud blank and two SPAL fans as big as I could fit. Had to position the fans around the water pump and install them on the shroud. Now it cools.
SPAL fans are good. Cheap fans are cheap.
[Re: DrCharles]
#3023620
03/13/22 02:59 PM
03/13/22 02:59 PM
Posts: 1,460 Martinsville, IN
cdwmotorsports
Martinsville, IN
I'm running the Ford Contour dual fans with an Autocoolguy PWM controller. 3-row 26" aluminum radiator. It fits the radiator like it was made for it. Brackets were simple. A little trimming of the plastic in the WP pulley area is needed - there is not a lot of room there! My big-cam 451 can idle all day at 182 degrees I too use that fan setup. I had to trim the center for my Meizere pump too in case some may think its only a stock pulley issue. I have a different brand controller though and I'm likely moving the fan control duties to the Holley Stealth Sniper system since it has the capability and will rid me of some extra wiring. Mine is also a 451" powered Demon
eBay-cdwmotorsports
[Re: cdwmotorsports]
#3023633
03/13/22 03:34 PM
03/13/22 03:34 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I have a $200 Afco radiator and $130 spal pusher. Keeps the temp 180* and never higher than 190* waiting in line for a car show or cruise in.
