Re: Anyone ever go faster with less lift?
[Re: mopar dave]
#3018044
02/23/22 02:17 PM
02/23/22 02:17 PM
Posts: 1,206 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Sorry for any confusion; yes, my rocker ratio tests were pre-Victor heads. Thx
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3018047
02/23/22 02:23 PM
02/23/22 02:23 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Sorry for any confusion; yes, my rocker ratio tests were pre-Victor heads. Thx No gains at the track, but there were some gains on the dyno as I recall? 5-10hp??
[Re: fast68plymouth]
#3018056
02/23/22 02:38 PM
02/23/22 02:38 PM
Brad_Haak
Loudoun County, VA
It was with my old ported '452' OEM heads, where I went from 1.5s I&E to 1.6s I&E and saw zip / nada / zilch show up at the track. I was really expecting some improvement, but... nope. It's not apples to apples, but it's at least one experience where more ratio got me nuttin'.
Intake-only 1.6s did show something like 5 HP w/ the Stage VIs on the dyno, but I ended up sticking with 1.5s on both I&E once the engine went into the car. The 1.5s went with the Stage VIs when they were sold.
When buying new rockers for the Victors, I went w/ 1.6s to go along with the switch to a solid roller. Fully loaded against a "real" spring they're 1.54-1.55 with a net (after lash) lift of ~ .650" w/ the RX roller.
[Re: Brad_Haak]
#3018102
02/23/22 03:50 PM
02/23/22 03:50 PM
Posts: 8,048 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Which brand rockers Brad? Got to say Dwayne is real close or spot on with the clearances he listed with retarding my cam per degrees. I over shot the 106 install degree and landed on 108. At 108 I measured .054 and .065 on intake and exhaust with .020 lash in each. I still have a 1.6/1.5 rocker combo. My math tells me it will be very close on both valves at 106. I’m sure it will take the 1.5 on the intake to get to an acceptable clearance. Hope to get more time this weekend.
[Re: mopar dave]
#3018127
02/23/22 04:59 PM
02/23/22 04:59 PM
Brad_Haak
Loudoun County, VA
I've used a number of different rocker brands and types. IIRC, the all 1.5s vs all 1.6s test used Rocker Arm Specialists 1.5 stainless-steel rollers and Crane "Gold" 1.6 aluminum.
The Stage VIs used Hughes (formerly Probe Industries) standard-offset 1.5 and 1.6 rockers.
The Victors have Hughes Victor-specific intake & standard exhaust 1.6 rockers.
The only ones I have pics of are the rockers on the Victors. The exhausts are their current "channeled" standard-offset style, while the intakes are their earlier "full body" .600"-offset style.
[Re: mopar dave]
#3018215
02/23/22 08:19 PM
02/23/22 08:19 PM
Posts: 10,042 Frostbitefalls MN (Rocky&Bullw...
gregsdart
On 440 -1 heads. They start life at 75cc?, Max stated cut is down to 62cc. But as Dwayne pointed out to me, work on the heads can alter how much would have to come off to get to 62cc. In my case it ended up being too much for high (15/1) compression, and i had to have a head welded and fixed. Now i have what i consider to be the ultimate set of moderate compression heads! Someday maybe on a BIG pumpgas street motor😁 So if you plan on buying new 440-1 heads, mike the deck thickness, and only cut them half of what it would take to get to 62cc. I think that would be . 040. Now you have a set of heads that can survive refinishing the decks more than once. At a multiple of cuts totaling . 080, they might not like super high compression or heavy doses of nitrous.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: mopar dave]
#3018371
02/24/22 09:40 AM
02/24/22 09:40 AM
gregsdart
I would love to see what would happen if you put an Isky RR735 rollercam in it. The cam is 278/288/110 . Intake lift is . 735 with a 1.5 rocker, lash was(?) .026 . .200 diration was close to 200 on intake, but it needs good valve springs. Not sure how much overkill i had, but i used Comp 947 tripples at 330 on the seat. Up the compression somehow to as much as you can run, and mid nines at 3500 lbs could happen. That cam was making 800 hp by 5700 rpm in a 4.5 bore 528 at 13.5 compression and peaked at 847 at 6900. I was using 1.55 Jesel rockers and . 043 rings, which from what i understand make a difference . But i like the power curve on that cam. It didn't seem to want more converter than about 5200 to 5600.
[Re: mopar dave]
#3018428
02/24/22 12:12 PM
02/24/22 12:12 PM
fast68plymouth
So. Burlington, Vt.
Was that .118/.140 figure measured before or after the heads were milled.045”?
Your old SFT lobe vs a moderately fast SR lobe of the same duration @.050”.......... the SR would only have about .015” more lobe lift at TDC with both installed at 106.
With the new cam installed at 106, what is the lobe lift at TDC?
The roller lobe I was using for comparison would be .154”
Here’s a dumb question......... You’re not trying to degree the new cam and check for clearances with a flat faced lifter, are you?
