Edelbrock avs2 #3016319
02/17/22 02:56 PM
02/17/22 02:56 PM
Palm Springs, Ca.
mopar71 Offline OP
mopar71  Offline OP
Palm Springs, Ca.
I have a 71charger 440hp with original carter 4968s carb with automatic heat choke and solenoid throttle stop plunger will the edelbrock avs2 connect with my original carter with out any issues(bolt holes etc)
Re: Edelbrock avs2 [Re: mopar71] #3016329
02/17/22 03:58 PM
02/17/22 03:58 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
90% sure NO. Unless it’s made for Chrysler specifically.
Re: Edelbrock avs2 [Re: mopar71] #3016333
02/17/22 04:11 PM
02/17/22 04:11 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
You'll need the throttle adapter and be losing the choke, you'll either be going electric or manual choke. If you've got some carburetor skills, you can follow along here:
https://board.moparts.org/ubbthread...rmostat-on-an-eddy-avs2.html#Post2998497
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Edelbrock avs2 [Re: 3hundred] #3016342
02/17/22 05:01 PM
02/17/22 05:01 PM
MO
cdp Offline
cdp  Offline
MO
Yep, throttle adapter, then transfer your carb stud to it. Bingo, you are done. Got one on my 71 RR and 71 GTX.
Re: Edelbrock avs2 [Re: cdp] #3016559
02/18/22 03:18 PM
02/18/22 03:18 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i think i'd work with the stock avs before i blew money on the edelbrock. the only real issue with the stock carbs is the lean idle/low speed circuit. the automatic transmission carbs have a leaner idle jet than the manuals. just set the carb up for the manual idle jet and make sure the mixture screws at the base of the carb are useable, .i prefer the edelbrock accelerator pumps to the old stock leathers, and i use edelbrock squirters but that's not a must. whole lot cheaper to do this than $400.
Re: Edelbrock avs2 [Re: lewtot184] #3016564
02/18/22 03:32 PM
02/18/22 03:32 PM
MA
steve70 Offline
steve70  Offline
MA
I did it on my 71 Charger R/T. I bought the throttle adapter and the AVS2 with electric choke. The car never ran so good and my low rpm hesitation went away.
1970 Challenger T/A 4 speed
Re: Edelbrock avs2 [Re: lewtot184] #3016566
02/18/22 03:35 PM
02/18/22 03:35 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You need to clarify what you mean when you say idle jet. Idle is controlled by the idle mixture screw not a jet. Do you mean the primary jets?
Re: Edelbrock avs2 [Re: Sniper] #3016593
02/18/22 04:59 PM
02/18/22 04:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
all carter afb's and their clones have an idle jet just like holleys have one. it's the small brass tube, next to the larger emulsion tube, that fits in the well. very simple. the edelbrock pamphlet that comes with the carbs shows it.
Re: Edelbrock avs2 [Re: lewtot184] #3016602
02/18/22 05:35 PM
02/18/22 05:35 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Good luck finding them
