Page 1 of 3 1 2 3
Cold fuel #3015619
02/15/22 12:09 PM
02/15/22 12:09 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Was racing down in Kentucky at a Mopar event last October.
Kinda had a pretty good handle on the numbers the car was running in different conditions at a new track( to me)
Next morning checked my fuel cell, almost out of gas(110)
I had purchased 5 gallons the day before, went back to hotel after racing, left the can sitting outside, dipped down into the upper 30’s over night, like it had the night before.
I dumped the “ cold fuel” into my cell, went up and shortly made a hit…
Car out of nowhere picked up 4 in the 1/8th.
Scratched my head about that, where in the world did that come from?
Only thing i can think of is the literally nearly ice cold fuel was the culprit.
If that situation ever repeats itself…..
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Cold fuel [Re: B3422W5] #3015631
02/15/22 12:27 PM
02/15/22 12:27 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
All you got was more fuel in the mix so test with more jet but the conditions may not replicate.
Re: Cold fuel [Re: Clanton] #3015639
02/15/22 12:48 PM
02/15/22 12:48 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Thats a lot but yes, I'd bet its the cold fuel. Engine masters did an episode trying to see if icing the intake helped, I forget all of the details but what they found was that it helped but it was because it made the carb bowls cold and the fuel was actually cooling the air charge alot, not that the cold manifold was lowering the IAT. The actual temp of the manifold was almost completely insignificant, but the fuel temp was important.
Remember everyone used to run those moroso cool cans? work
Re: Cold fuel [Re: GTX MATT] #3015641
02/15/22 12:59 PM
02/15/22 12:59 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
My buddy used to race drag bikes, they had small tanks (less than a gallon) He used to keep the fuel in a milk jug, in a cooler full of ice
....BAD A$$ STREET CAR.....
Re: Cold fuel [Re: B3422W5] #3015645
02/15/22 01:08 PM
02/15/22 01:08 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Any on e ever hear of a "COOL CAN" it was a 1gal ish sized can under the hood that the fuel line ran through. just before each run you would pack it with Ice to cool the fuel during the run...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Cold fuel [Re: GTX MATT] #3015646
02/15/22 01:08 PM
02/15/22 01:08 PM
an8sec70cuda Offline
I have a friend that tried a Moroso cool can years ago. He said when he packed it with ice, it would make his fuel pressure drop from 7 to around 3 psi. It still ran fine, but that bothered him so he removed the cool can.
I have never used a cool can, but have any of you seen this? It makes sense since the fuel is cooler and denser. Do you reset the regulator so the pressure is back up to normal or what?
They're one of those old school hot rod parts nobody uses anymore. shruggy
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Cold fuel [Re: an8sec70cuda] #3015647
02/15/22 01:11 PM
02/15/22 01:11 PM
Byron, NY
Byron, NY
The early ones were nothing more than a can wrapped with cork with a metal lid that that just rested on top. Later versions were better insulated and sealed.
'60 Willys CJ5
Re: Cold fuel [Re: W.I.N. Racing] #3015649
02/15/22 01:20 PM
02/15/22 01:20 PM
moparx Offline
moparx  Offline
didn't NHRA outlaw those because of water on the track issues ?
beer
Re: Cold fuel [Re: W.I.N. Racing] #3015650
02/15/22 01:20 PM
02/15/22 01:20 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I think i actually ran a cool can on a car back in the 70’s it was kinda a thing most everybody did.
That said, the result i had that morning i think was way different than a cool can
I dumped gas in my cell that was probably 42-45 degrees and in short order was sucking that stuff into the motor.
You take a typical day, the fuel is never that cool, even a cool can( i doubt) will cool all the inbound fuel to that temp..although i could be wrong
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Cold fuel [Re: B3422W5] #3015663
02/15/22 02:24 PM
02/15/22 02:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Don, did the gas in the car and the can come from the same source? Was the carb tuned in hot weather?
Re: Cold fuel [Re: B3422W5] #3015664
02/15/22 02:25 PM
02/15/22 02:25 PM
UK
rb446 Offline
rb446  Offline
UK
Carb heat plates, Cool cans, wooden carb spacers etc......The Rossi Challenger run by the Hausers over here had a cool can, watched a guy@ Santa Pod running 10.10's pack the manifold with Ice before a run and went into the 9's.....cool it, it works, has done for yonks.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Cold fuel [Re: W.I.N. Racing] #3015671
02/15/22 02:43 PM
02/15/22 02:43 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Speaking in a glittering generality here but the colder the fuel the quicker you will be...We make every effort possible to keep the fuel as cold as possible in the heads up car. In a bracket car its not very practical honestly.
Re: Cold fuel [Re: justinp61] #3015674
02/15/22 02:50 PM
02/15/22 02:50 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Same stuff. I tune for shoulder weather, early and late summer. Leave it alone for spring and fall. Bracket car..moves around the least doing that seems like.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Cold fuel [Re: B3422W5] #3015681
02/15/22 03:05 PM
02/15/22 03:05 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
I can't hang a number on it as I don't have that kind of experience.
But I remember seeing a someone else's test a little while back, entire intake and carb was iced during a dyno test.
Temp guns on the manifold showed it heated back up to where it was almost instantly,
as did the air temperature, But the carb and the fuel did not.
It picked up and they pointed to cold fuel, given all else.
Seems to agree.
Rich H.
Esse Quam Videri
Re: Cold fuel [Re: ZIPPY] #3015702
02/15/22 04:29 PM
02/15/22 04:29 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
cool cans are legal in nhra stock, moroso makes a polyurethane 65125, cannot be mounted on firewall, plumbing my stocker for one
65125 was 3/8 npt now 65127 #8 AN
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Cold fuel [Re: 440lebaron] #3015722
02/15/22 05:30 PM
02/15/22 05:30 PM
Suffolk,VA
dragracedr Offline
dragracedr  Offline
Suffolk,VA
don't forget dry ice in the fuel cell.
Re: Cold fuel [Re: ZIPPY] #3015792
02/15/22 09:03 PM
02/15/22 09:03 PM
I've seen many NHRA class racers ice the intake to gain a tiny advantage when they thought they needed it in a heads up class run offs at the Winternationals and the World Finals at Pomona more than once wrench
Re: Cold fuel [Re: dragracedr] #3015816
02/15/22 09:36 PM
02/15/22 09:36 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
At a NHRA divisional race a couple of years ago, my fuel check after a qualifying run was marginal. The tech guy asked me if I had put dry ice in the fuel cell. It happens.
1979 AMC Spirit, NHRA Q/SA
Re: Cold fuel [Re: longram60] #3015862
02/16/22 12:41 AM
02/16/22 12:41 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
When we were racing my Buick we had a cool can on it. One day I pulled into staging when it was about 100 out. My buddy Russell pops the hood open, and pulls a can of Pepsi out of the cool can. People freaked out.
Re: Cold fuel [Re: longram60] #3015944
02/16/22 11:52 AM
02/16/22 11:52 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Dry ice .....interesting work who does this work?
Page 1 of 3 1 2 3
