We Have Ignition!! Stays lit, with Video!!
#3015256
02/14/22 09:02 AM
02/14/22 09:02 AM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
All, Finally put fuel in - wanted to start the car and get transmission fluid in, make sure there's no leaks etc..... Car fired right away - and died. Did the same thing a few more times, I knew it wasn't fuel. Held the key in the start position brief extra second, engine will stay running. MSD Digital 6AL is wired per MSD directions, original wiring is in car to the MSD. I'm pretty sure this has been encountered before, it sounds familiar. Any advice/suggestions are greatly appreciated!!
Thanks All!
Wally.
Re: We Have Ignition!! And then it dies.....MSD.
[Re: wkroncke17]
#3015260
02/14/22 09:13 AM
02/14/22 09:13 AM
Posts: 9,822 MI, usa
dvw
MI, usa
The Chrysler factory ignition switch has two outputs. The brown wire is hot in crank only, not run. The blue wire is hot in run only, not crank. They must be tired together when running anything other than a stock ignition with the ballast resistor. Both wires are located at the ballast resistor. Tie them together to feed the small red ignition on wire at your MSD. Doug
[Re: dvw]
#3015296
02/14/22 11:00 AM
02/14/22 11:00 AM
wkroncke17
Wisconsin
The Chrysler factory ignition switch has two outputs. The brown wire is hot in crank only, not run. The blue wire is hot in run only, not crank. They must be tired together when running anything other than a stock ignition with the ballast resistor. Both wires are located at the ballast resistor. Tie them together to feed the small red ignition on wire at your MSD. Doug I knew it would be something fairly simple - even for an electrical imbecile like me! I'll get to it sometime this week and report back. Thank you very much!! Wally.
[Re: dvw]
#3015537
02/14/22 10:20 PM
02/14/22 10:20 PM
wkroncke17
Wisconsin
The Chrysler factory ignition switch has two outputs. The brown wire is hot in crank only, not run. The blue wire is hot in run only, not crank. They must be tired together when running anything other than a stock ignition with the ballast resistor. Both wires are located at the ballast resistor. Tie them together to feed the small red ignition on wire at your MSD. Doug Just to be 100% correct, the blue wire that goes to the alternator and back to “N” in the bulkhead connector, correct? BTW, I still have externally regulated alternator. Thank you!
[Re: NITROUSN]
#3015588
02/15/22 08:26 AM
02/15/22 08:26 AM
dvw
MI, usa
Correct, with this set up using an MSD you would tie the wires from Q and N together to feed the MSD ignition (small red wire at the MSD box). Also the factory coil feed and distributor circuits from the factory ignition box must be taped off, or removed. There would be a cross feed with the brown wire from terminal Q in the bulkhead and the MSD coil wiring. Doug
[Re: dvw]
#3015707
02/15/22 04:38 PM
02/15/22 04:38 PM
Posts: 888 Oh
parksr5
Oh
The Chrysler factory ignition switch has two outputs. The brown wire is hot in crank only, not run. The blue wire is hot in run only, not crank. They must be tired together when running anything other than a stock ignition with the ballast resistor. Both wires are located at the ballast resistor. Tie them together to feed the small red ignition on wire at your MSD. Doug I went through the same challenges as the original poster about 20+ years ago on my car, when it was owned by my brother. Car would fire up in the crank position and immediately die. After messing around for about 10 minutes, I found the solution but, my brother didn't agree. We chased other stuff for probably over 2 hours, and I kept suggesting the above. He was frustrated and yelled at me saying that he didn't want to do the above as he thought something would burn up. I told him that it was a fused circuit, so; if it was wrong, the fuse would pop. He wouldn't listen. Finally, he had to go in the house to use the bathroom, so; once he was out of sight, I twisted the wires together and fired the car within like 20 seconds. He walked back out shortly after to find what I'd done. Didn't gloat or anything but, pretty much said, I told you so.
[Re: parksr5]
#3016180
02/16/22 10:58 PM
02/16/22 10:58 PM
wkroncke17
Wisconsin
was your brother older or younger than you ? Older, by about 4 years. Good for you!! That’s a great story!
[Re: wkroncke17]
#3016292
02/17/22 01:23 PM
02/17/22 01:23 PM
Posts: 19,336 north of coder
moparx
was your brother older or younger than you ? Older, by about 4 years. Good for you!! That’s a great story! like my old man would say : "that'll learn 'im !" yes sir, great story indeed !
Re: We Have Ignition!! Stays lit with video!
[Re: moparx]
#3016418
02/17/22 11:26 PM
02/17/22 11:26 PM
wkroncke17
Wisconsin
Isn’t it amazing how the older we get, the Smarter the ‘old man was? I think that every day. BTW - we have ignition!!!! And it stays LIT! Tried to attach video, no luck. https://m.youtube.com/watch?v=cHZzcspl0KM
[Re: wkroncke17]
#3016763
02/19/22 01:14 PM
02/19/22 01:14 PM
moparx
Isn’t it amazing how the older we get, the Smarter the ‘old man was? I think that every day. BTW - we have ignition!!!! And it stays LIT! Tried to attach video, no luck. https://m.youtube.com/watch?v=cHZzcspl0KM video sounds good ! as to the old man, you bet ! until the day he died, whenever we saw each other, he would look up at the top of my head and say : "i got hair, you don't ! " "lets the smarts out !" my old man had a lot of "smarta$$ery" remarks, and another one he liked to say when you wacked yourself and were dancing around making up "new" words was : "I didn't feel a thing !"
[Re: AndyF]
#3016806
02/19/22 03:14 PM
02/19/22 03:14 PM
wkroncke17
Wisconsin
[spoiler][/spoiler] Sounds good. I see some AR Engineering parts on there. Looks good! I bought them directly from you Andy. Fit perfect, work great and look good! Thank you sir!
[Re: moparx]
#3016811
02/19/22 03:17 PM
02/19/22 03:17 PM
wkroncke17
Wisconsin
Isn’t it amazing how the older we get, the Smarter the ‘old man was? I think that every day. BTW - we have ignition!!!! And it stays LIT! Tried to attach video, no luck. https://m.youtube.com/watch?v=cHZzcspl0KM video sounds good ! as to the old man, you bet ! until the day he died, whenever we saw each other, he would look up at the top of my head and say : "i got hair, you don't ! " "lets the smarts out !" my old man had a lot of "smarta$$ery" remarks, and another one he liked to say when you wacked yourself and were dancing around making up "new" words was : "I didn't feel a thing !" That’s awesome! 😂 My dads favorite was “Don’t let your mouth overload your a$$” I’m sure we could quote them every day.
