pulley install (too much interference?) UPDATE
#3014112
02/10/22 06:03 PM
02/10/22 06:03 PM
Posts: 4,681 Florida
BDW
I have this pulley I'm trying to install. It's a Holley power steering kit for a 3G motor. First attempt was a total failure, wouldn't go on, and then it got cocked and gouged the powder coat on the pulley. I've now measured the power steering shaft (steel) and it's 0.668" and the aluminum pulley is 0.660". Is this normal, or is the powder coat too thick? It's circular, so that's 0.004" around the complete diameter to overcome.
Re: pulley install (too much interference?)
[Re: BDW]
#3014174
02/10/22 10:38 PM
02/10/22 10:38 PM
Posts: 1,263 New York, USA
Chargerfan68
New York, USA
.008” is way too much interference fit. Just for reference, an ATI super damper (harmonic bal) specs at .0008” to crank. In my opinion, there should not be any powdercoat on the inside pulley to shaft surface.
[Re: NITROUSN]
#3014185
02/10/22 11:14 PM
02/10/22 11:14 PM
BDW
I’m going to have to hit the inside of the pulley with some sandpaper to clean up the gouge. Just don’t want to take off too much. Here’s the tool, seems simple enough, thread in the stud, then crank down the nut to pull the pump onto the pulley.
[Re: BDW]
#3014934
02/13/22 09:59 AM
02/13/22 09:59 AM
BDW
Cleaned off most of the powder coating with a Dremel tool and gave it another go. Inside diameter interference is now ~0.004” It was a mutha to pull on, but it’s done. Appreciate the help
Re: pulley install (too much interference?) UPDATE
[Re: RapidRobert]
#3014983
02/13/22 12:10 PM
02/13/22 12:10 PM
Chargerfan68
New York, USA
Glad you got it done! Nice!
[Re: BDW]
#3015178
02/13/22 10:10 PM
02/13/22 10:10 PM
Posts: 15,197 Omaha Ne
TJP
Omaha Ne
[Re: 1969ronnie]
#3015309
02/14/22 11:37 AM
02/14/22 11:37 AM
Posts: 20 SWFL
Tie Rod Garage
SWFL
that finish looks more like anodizing, not powder coating. Normally threaded holes and press fit holes get masked when powder coated. It's typically not necessary when anodizing.
1941 Dodge WC, 493 cid twin turbo FAST XFI 2002 Dakota R/T RC
