what plugs for EQ heads? #3014656
02/12/22 11:37 AM
02/12/22 11:37 AM
RapidRobert Offline OP
EQ genuine new zealand iron heads. champion rn12yc and autolite 3924 & 5224 are too short (recessed in the combustion chamber about 4 threads). autolite 5325 are too long & intrude into the combustion chamber significantly. what brand/number do I need. I will be racing. thank you for your time.
Re: what plugs for EQ heads? [Re: RapidRobert] #3014685
02/12/22 01:36 PM
02/12/22 01:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
RN12YC is 3/4 inch reach.
RJ12YC is 3/8 inch reach.
There are 1/2 inch reach available.
What is recommended by the head company?
Re: what plugs for EQ heads? [Re: NITROUSN] #3014787
02/12/22 07:39 PM
02/12/22 07:39 PM
not exact but I think I need ~1" reach. I 'm trying to get ahold of eric haugland of las vegas who I purchased these heads from way back (midwest something iirc)
Re: what plugs for EQ heads? [Re: RapidRobert] #3014808
02/12/22 08:23 PM
02/12/22 08:23 PM
N
NITROUSN Offline
NITROUSN  Offline
N
1 inch never heard of them Not that there might be some.
Re: what plugs for EQ heads? [Re: RapidRobert] #3014810
02/12/22 08:29 PM
02/12/22 08:29 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I just googled 1 inch reach spark plugs and yes they are out there. Do not know why someone would make a head requiring an exotic plug like that.
Re: what plugs for EQ heads? [Re: NITROUSN] #3014892
02/13/22 03:34 AM
02/13/22 03:34 AM
I will make an accurate measurement & go from there & continue to call the online #'s for Eric. thanks guys EDIT I googled & you are correct, they are available, just need an accurate measurement.
Re: what plugs for EQ heads? [Re: RapidRobert] #3015370
02/14/22 02:24 PM
02/14/22 02:24 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Because we seem to be aware 3/4" reach plugs are design intent in that style of head, I couldn't let that go in good conscience.
I'd recommend correcting the machining error by spot facing the spark plug holes to the required depth, rather than sticking someone in the future with an oddball spark plug.
Rich H.
