Re: New Product - '62-'72 A-Body 5 x 4.5" pattern 7.25" axles
[Re: Rhinodart]
#3014815
02/12/22 08:42 PM
02/12/22 08:42 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
73-76 7.25 with BBP has a larger wheel bearing on it Jim. The spacing for the brake is also different.
[Re: slantzilla]
#3014822
02/12/22 09:01 PM
02/12/22 09:01 PM
Posts: 6,261 nowhere
Sniper
nowhere
73-76 7.25 with BBP has a larger wheel bearing on it Jim. The spacing for the brake is also different. I assume Dr Diff's new LBP axles would use the normal 4.5" pattern brakes so they ought to have the same spacing as the 73-76 axles do.
[Re: Sniper]
#3014971
02/13/22 11:32 AM
02/13/22 11:32 AM
Posts: 16,147 Mesa, Arizona
dart4forte
Mesa, Arizona
So, can the 73 and up 7.25 10” brake drums and backing plates be used on a 8.75?
Abe Lincoln
[Re: dart4forte]
#3015127
02/13/22 07:47 PM
02/13/22 07:47 PM
slantzilla
Park Forest, IL
So, can the 73 and up 7.25 10” brake drums and backing plates be used on a 8.75? Yes, I've done it multiple times.
[Re: DoctorDiff]
#3016353
02/17/22 06:09 PM
02/17/22 06:09 PM
Posts: 43,555 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
''73 and newer 5 x 4.5" bolt pattern brakes taken from a 7.25" rear will interchange onto a 5 x 4.5" bolt pattern 8.75" rear.
My new 5 x 4.5" bolt pattern 7.25" conversion axles use stock '72 and earlier 9" or 10" A-body drum brake hardware and backing plates. You must re-drill the brake drums or purchase my new 5 x 4.5" bolt pattern drums. As always, you DA MAN Cass!
JB Rhinehart, Realist
A-Body's RULE!
