what plugs for EQ heads?
#3014656
02/12/22 11:37 AM
02/12/22 11:37 AM
RapidRobert
EQ genuine new zealand iron heads. champion rn12yc and autolite 3924 & 5224 are too short (recessed in the combustion chamber about 4 threads). autolite 5325 are too long & intrude into the combustion chamber significantly. what brand/number do I need. I will be racing. thank you for your time.
Re: what plugs for EQ heads?
[Re: NITROUSN]
#3014787
02/12/22 07:39 PM
02/12/22 07:39 PM
RapidRobert
not exact but I think I need ~1" reach. I 'm trying to get ahold of eric haugland of las vegas who I purchased these heads from way back (midwest something iirc)
[Re: RapidRobert]
#3014810
02/12/22 08:29 PM
02/12/22 08:29 PM
Posts: 18,406 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
not exact but I think I need ~1" reach. I 'm trying to get ahold of eric haugland of las vegas who I purchased these heads from way back (midwest something iirc) I just googled 1 inch reach spark plugs and yes they are out there. Do not know why someone would make a head requiring an exotic plug like that.
[Re: NITROUSN]
#3014892
02/13/22 03:34 AM
02/13/22 03:34 AM
RapidRobert
I will make an accurate measurement & go from there & continue to call the online #'s for Eric. thanks guys EDIT I googled & you are correct, they are available, just need an accurate measurement.
[Re: RapidRobert]
#3015370
02/14/22 02:24 PM
02/14/22 02:24 PM
Posts: 17,836 S.E. Michigan
ZIPPY
S.E. Michigan
Because we seem to be aware 3/4" reach plugs are design intent in that style of head, I couldn't let that go in good conscience.
I'd recommend correcting the machining error by spot facing the spark plug holes to the required depth, rather than sticking someone in the future with an oddball spark plug.
Rich H.
Esse Quam Videri
