cylinder head cut a way #3014359
02/11/22 02:36 PM
02/11/22 02:36 PM
Atlanta, GA
mgoblue9798 Offline OP
Atlanta, GA
I have a 413 -3 head that I want to do cut aways on the ports to find the thin spots and where the water is. Would a 14" chop saw with a metal cutting saw blade work, or would I need to take it somewhere that has an industrial sized band saw?
Not at all interested in hearing how bad the heads are as they will be used in an RV application and are perfect for that purpose.
Re: cylinder head cut a way [Re: mgoblue9798] #3014394
02/11/22 03:56 PM
02/11/22 03:56 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
a band saw would have a thinner cut, would not need to be that big of a saw just go slow
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: cylinder head cut a way [Re: 440lebaron] #3014414
02/11/22 04:51 PM
02/11/22 04:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Been there and done that. Was a total waste of time and money. Unless you're hogging these out for a prostock application there is sufficient material in all the right places for a mild porting job. If you plan to port to the max, cutting one head to see thin spots doesn't mean the head you port will be better or worse. You'd be far further ahead to buy a set of the Direct Connection porting templates and use those. Those pretty much guaranty you won't grind into a water jacket and the end results actually provide a performance gain.
Re: cylinder head cut a way [Re: Stanton] #3014422
02/11/22 05:02 PM
02/11/22 05:02 PM
Atlanta, GA
Atlanta, GA
Thanks for the input. These are a different casting altogether than a regular big block. Completely different. I guess I might be better off grinding on a spare head to see. Particularly concened about hitting water as these have water all over the place even cooling the spark plug.
Re: cylinder head cut a way [Re: mgoblue9798] #3014458
02/11/22 06:28 PM
02/11/22 06:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If they're being used in an RV, just what are you hoping to gain by hogging them out? I think you're flogging a dead horse.
Re: cylinder head cut a way [Re: Stanton] #3014679
02/12/22 01:12 PM
02/12/22 01:12 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Isn't the 413-3 that goofy big truck engine with the oddball heads, water pump, intake, exhausts, and a bunch of other differences compared to a typical RB?
Re: cylinder head cut a way [Re: 6PakBee] #3014681
02/12/22 01:25 PM
02/12/22 01:25 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Yes it is.
Re: cylinder head cut a way [Re: mgoblue9798] #3014948
02/13/22 10:35 AM
02/13/22 10:35 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
yes a 14 in chop saw will do it.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: cylinder head cut a way [Re: 6PakBee] #3014999
02/13/22 12:46 PM
02/13/22 12:46 PM
Atlanta, GA
Atlanta, GA
Yes, that is why I was considering cutting one open to see what is what. Next to no info out there about anyone playing with them. Among the goofy differences are a large closed chamber and a spark plug in the center like a small block head.
Re: cylinder head cut a way [Re: mgoblue9798] #3016449
02/18/22 09:06 AM
02/18/22 09:06 AM
Monroe NC
Luvcars69 Offline
Luvcars69  Offline
Monroe NC
I use an ultrasonic tester when porting it reveals everything. They are a little pricey, I bought a new GE for about $1500 20 years ago, maybe find a used one for sale.
Making cars faster one at a time!
19 Challenger Scat Pack white
16 Ram Sport SB Regular cab black
14 Charger Pursuit silver
78 Magnum 400 gray
69 SuperBee 512 Passion 4-speed 4:10
Re: cylinder head cut a way [Re: mgoblue9798] #3016538
02/18/22 02:14 PM
02/18/22 02:14 PM
AndyF Offline
AndyF  Offline
A big bandsaw works the best but you can try the chop saw. Wear some ear plugs and eye goggles, it will be noisy and you'll have chips and sparks flying around.
Re: cylinder head cut a way [Re: AndyF] #3016588
02/18/22 04:46 PM
02/18/22 04:46 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
One of our members posted some very nice pictures of a 906 head cut up on Facebook. I should have probably saved those pictures but I stick to porting aluminum only now.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
