LOCK OUT DIST #3014019
02/10/22 01:12 PM
02/10/22 01:12 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
building a locked out OEM bigblock electric distributor, i welded weights, does not have a vacuum can on it (missing), need to lock down pickup coil, does the coil pivot all the way back or is it centered on the plate, (if you follow what i mean?? stock coil pivots on plate)
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: LOCK OUT DIST [Re: 440lebaron] #3014045
02/10/22 02:31 PM
02/10/22 02:31 PM
moparx Online content
moparx  Online Content
wouldn't that be the same, or similar to, a lean burn distributor ?
i think those plates were riveted fast, but i can't say in what position.
and didn't some of those have two pickups, with one being retarded for starting ?
those have been a looong time ago, so please don't beat on me too hard if i'm not close to correct on this.
beer
Re: LOCK OUT DIST [Re: moparx] #3014056
02/10/22 03:26 PM
02/10/22 03:26 PM
westerly, ri. usa
westerly, ri. usa
70's style single pickup, vacuum can pulls it on flexible (pivot) plate. question might be where is pickup plate when vacuum can is installed? my vacuum can is missing (not using now) was on originally
Re: LOCK OUT DIST [Re: 440lebaron] #3014074
02/10/22 04:28 PM
02/10/22 04:28 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
one of these industrial plates and a lean burn shaft should get you where you want to be.
Re: LOCK OUT DIST [Re: lewtot184] #3014082
02/10/22 04:42 PM
02/10/22 04:42 PM
westerly, ri. usa
westerly, ri. usa
napa/echlin MP810 n/a, above photo looks like right in center
vacuum distributor i can move pickup back and fourth 10-15* from center
Re: LOCK OUT DIST [Re: 440lebaron] #3014115
02/10/22 06:18 PM
02/10/22 06:18 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think you'd want to phase that distributor cap and rotor and then position the pickup relative to the lobe and only then lock down the plate.
Re: LOCK OUT DIST [Re: Stanton] #3014121
02/10/22 06:41 PM
02/10/22 06:41 PM
pennsylvania
poboyengineering Offline
pennsylvania
I did one years ago, and moved the advance weights to the fully advanced position
in order to get the phasing right.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: LOCK OUT DIST [Re: poboyengineering] #3014281
02/11/22 11:45 AM
02/11/22 11:45 AM
Washington
madscientist Offline
Washington
Why are you locking it out? Unless you are going to control timing with an ignition box of some sort, you’ll never know how much timing you really have. I’d rethink the lock out.
Re: LOCK OUT DIST [Re: madscientist] #3014321
02/11/22 01:13 PM
02/11/22 01:13 PM
westerly, ri. usa
westerly, ri. usa
always ran race car with locked out timing 32-38* use start retard and 3rd gear retard, just building my own distributor
Re: LOCK OUT DIST [Re: madscientist] #3014323
02/11/22 01:15 PM
02/11/22 01:15 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've used leanburn distributors forever. Along with a crank trigger. Spins the rotor in the cap. That's it. Rock steady timing when you eliminate the timing chain, cam, drive shaft, oil pump, etc, etc.
No reason you couldn't use the OE pickup if you didn't want a crank trigger. Just needs to be wired correctly for the MSD.
Re: LOCK OUT DIST [Re: CMcAllister] #3014546
02/11/22 10:55 PM
02/11/22 10:55 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted by CMcAllister
I've used leanburn distributors forever. Along with a crank trigger. Spins the rotor in the cap. That's it. .
I have one too........
Re: LOCK OUT DIST [Re: markz528] #3014562
02/12/22 12:02 AM
02/12/22 12:02 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Price is right. Works perfectly.
Re: LOCK OUT DIST [Re: 440lebaron] #3014573
02/12/22 12:34 AM
02/12/22 12:34 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
As I remember just use a 3/16 rivet and a washer between the pickup plate and the distributor plate, use the hole where the advance hooked into the pickup plate, drill into the distributor plate. Then I just cut a strip of aluminum and screwed it over the hole where the advance unit went, did a bunch back in the day.
Re: LOCK OUT DIST [Re: Stanton] #3014951
02/13/22 10:39 AM
02/13/22 10:39 AM
^ this. leave the can installed then pump up the can till the rotor phasing is dead on & drill down thru both both plates for a small bolt/spacer/nut install to lock it in that position then take it apart & clean it up & go back together.
Re: LOCK OUT DIST [Re: RapidRobert] #3015367
02/14/22 02:16 PM
02/14/22 02:16 PM
westerly, ri. usa
westerly, ri. usa
look what i found
