Reverse lights don’t work #3013846
02/09/22 07:34 PM
02/09/22 07:34 PM
Runner1 Offline OP
Runner1  Offline OP
Hello!
I have a 68 coronet, auto 727, and my reverse lights don’t work. I have the single prong neutral safety switch, replaced that and the wire to the starter relay.
Followed the reverse light wire to the bulkhead on the kick panel, and followed it from there to the firewall bulk harness. There are no wires connected to it from firewall bulkhead to the engine harness.
Checked the wiring schematic and all looks correct.
Can anyone provide assistance
Thx
Re: Reverse lights don’t work [Re: Runner1] #3013849
02/09/22 07:51 PM
02/09/22 07:51 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I'm not sure if 68 Dodge is the same as 68 Plymouth... On my 68 Road Runner (column automatic) the reverse light switch is located at the very bottom of the steering column by the firewall. There is a small plastic spike that actuates the switch. It is easily lost or broken. You loosen the attaching hardware to rotate for switch adjustment.
Re: Reverse lights don’t work [Re: 68jim] #3013856
02/09/22 08:39 PM
02/09/22 08:39 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Yep that black post broke on my '68 Road Runner column automatic. I found the broken post and repaired it with a sheet metal screw through the center of the broken post. Then found a new one and held on to it if the repair didn't hold probably still in the glovebox still waiting for the call.
Re: Reverse lights don’t work [Re: A12] #3013862
02/09/22 08:55 PM
02/09/22 08:55 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Just pulled up some old photos of that black reverse switch pin and I think what happed to mine was that the four tabs at the base were worn and the pin wouldn't stay in the column? I think I push a plastic pin or tube inside of the end of it down to those four tabs at the base to spread them and that helped to keep it secured to the column? Don't know where I found a new reverse pin/post but that's the best fix if it is the problem......or you can try this.
Re: Reverse lights don’t work [Re: A12] #3013869
02/09/22 09:05 PM
02/09/22 09:05 PM
Runner1 Offline OP
Runner1  Offline OP
My car is an auto on the console, I don’t think I have that black switch I’ll check in the morning thx for the response
Re: Reverse lights don’t work [Re: Runner1] #3013875
02/09/22 09:13 PM
02/09/22 09:13 PM
Runner1 Offline OP
Runner1  Offline OP
Here is a pic of my console, auto on console
Photo attached thx
Re: Reverse lights don’t work [Re: Runner1] #3013876
02/09/22 09:25 PM
02/09/22 09:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Well thank goodness and hopefully it doesn't need that little plastic pin because I remember it being really stupid expensive for a piece of PLASTIC. This is what I just found and REALLY ARE YOU S#!**!&@ ME https://www.moparmall.com/MoPar-p-n-2883211-Reverse-Lamp-Switch-Pin-p/801-547.htm
Am I reading that price correctly scope
Re: Reverse lights don’t work [Re: A12] #3013880
02/09/22 09:36 PM
02/09/22 09:36 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
moparmall is a great way to overspend on stuff
Re: Reverse lights don’t work [Re: Sniper] #3013899
02/09/22 11:03 PM
02/09/22 11:03 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
The reverse light switch pin broke on my '68 Valiant back in the '70's and the price was crazy even back then. I added a toggle switch for the lights to come on manually instead of automatically. It got me by the state safety inspection so I was happy.
Re: Reverse lights don’t work [Re: Powerflow] #3013944
02/10/22 08:24 AM
02/10/22 08:24 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
If you make a harness to extend the black and white wires to the neutral safety switch and change comb/ switch to 3 prong you don't need the column/console/shifter switch anymore.
Re: Reverse lights don’t work [Re: Runner1] #3014010
02/10/22 12:38 PM
02/10/22 12:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's what the console BU light switch looks like.
Re: Reverse lights don’t work [Re: B1MAXX] #3014024
02/10/22 01:28 PM
02/10/22 01:28 PM
moparx Offline
moparx  Offline
the rooster comb on the valvebody needs changed as well to use the 69 up three prong NSS.
just clarifying the above statement in case anyone may be confused.
beer
Re: Reverse lights don’t work [Re: moparx] #3014051
02/10/22 02:47 PM
02/10/22 02:47 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have the opposite issue with my car (70 Challenger). The reverse light stays on in every gear except park. Off in park but on in R, N, 1,2,3 with RMVB and a transbrake.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Reverse lights don’t work [Re: 6PKRTSE] #3014136
02/10/22 07:38 PM
02/10/22 07:38 PM
Runner1 Offline OP
Runner1  Offline OP
Thank you guys appreciate the help! Couldn’t find that damn switch now I know!!
Re: Reverse lights don’t work [Re: 6PKRTSE] #3014336
02/11/22 01:49 PM
02/11/22 01:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The BU lights are controlled by the metal contact in the switch (red circle below), as long as the contact is extended the lights are on, when the contact is depressed by the plastic shoe the lights are off. If the plastic shoe is broken, the contact will remain extended in gears other than Reverse.
Re: Reverse lights don’t work [Re: John_Kunkel] #3014345
02/11/22 02:07 PM
02/11/22 02:07 PM
moparx Offline
moparx  Offline
the lights will stay on if the plastic part is loose on the rooster comb as well.
they are usually broken as John says, but i ran into this one time, and pulled a bunch of hair out of my head until i clamped the retaining tabs a little tighter on the plastic shoe piece.
i didn't think being a little loose would matter if the shoe was not broken, but after snugging it up, the lights worked as they should, only on in reverse.
the plastic was just loose enough to allow the pin to push on the plastic, moving it just enough to complete the circuit.
drove me nutz until i figured it out. runaway
beer
