LOCK OUT DIST
#3014019
02/10/22 01:12 PM
02/10/22 01:12 PM
Posts: 1,602 westerly, ri. usa
440lebaron
westerly, ri. usa
building a locked out OEM bigblock electric distributor, i welded weights, does not have a vacuum can on it (missing), need to lock down pickup coil, does the coil pivot all the way back or is it centered on the plate, (if you follow what i mean?? stock coil pivots on plate)
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: LOCK OUT DIST
[Re: 440lebaron]
#3014045
02/10/22 02:31 PM
02/10/22 02:31 PM
Posts: 19,307 north of coder
moparx
wouldn't that be the same, or similar to, a lean burn distributor ? i think those plates were riveted fast, but i can't say in what position. and didn't some of those have two pickups, with one being retarded for starting ? those have been a looong time ago, so please don't beat on me too hard if i'm not close to correct on this.
Re: LOCK OUT DIST
[Re: moparx]
#3014056
02/10/22 03:26 PM
02/10/22 03:26 PM
440lebaron
westerly, ri. usa
70's style single pickup, vacuum can pulls it on flexible (pivot) plate. question might be where is pickup plate when vacuum can is installed? my vacuum can is missing (not using now) was on originally
Re: LOCK OUT DIST
[Re: lewtot184]
#3014082
02/10/22 04:42 PM
02/10/22 04:42 PM
440lebaron
westerly, ri. usa
napa/echlin MP810 n/a, above photo looks like right in center vacuum distributor i can move pickup back and fourth 10-15* from center
Re: LOCK OUT DIST
[Re: Stanton]
#3014121
02/10/22 06:41 PM
02/10/22 06:41 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
I did one years ago, and moved the advance weights to the fully advanced position in order to get the phasing right.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: LOCK OUT DIST
[Re: poboyengineering]
#3014281
02/11/22 11:45 AM
02/11/22 11:45 AM
Posts: 4,457 Washington
madscientist
Washington
Why are you locking it out? Unless you are going to control timing with an ignition box of some sort, you’ll never know how much timing you really have. I’d rethink the lock out.
Re: LOCK OUT DIST
[Re: madscientist]
#3014321
02/11/22 01:13 PM
02/11/22 01:13 PM
440lebaron
westerly, ri. usa
always ran race car with locked out timing 32-38* use start retard and 3rd gear retard, just building my own distributor
Re: LOCK OUT DIST
[Re: madscientist]
#3014323
02/11/22 01:15 PM
02/11/22 01:15 PM
Posts: 11,491 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've used leanburn distributors forever. Along with a crank trigger. Spins the rotor in the cap. That's it. Rock steady timing when you eliminate the timing chain, cam, drive shaft, oil pump, etc, etc.
No reason you couldn't use the OE pickup if you didn't want a crank trigger. Just needs to be wired correctly for the MSD.
Re: LOCK OUT DIST
[Re: CMcAllister]
#3014546
02/11/22 10:55 PM
02/11/22 10:55 PM
Posts: 4,269 Morrow, OH
markz528
Morrow, OH
I've used leanburn distributors forever. Along with a crank trigger. Spins the rotor in the cap. That's it. . I have one too........
Re: LOCK OUT DIST
[Re: markz528]
#3014562
02/12/22 12:02 AM
02/12/22 12:02 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've used leanburn distributors forever. Along with a crank trigger. Spins the rotor in the cap. That's it. . I have one too........ Price is right. Works perfectly.
Re: LOCK OUT DIST
[Re: Stanton]
#3014951
02/13/22 10:39 AM
02/13/22 10:39 AM
RapidRobert
I think you'd want to phase that distributor cap and rotor and then position the pickup relative to the lobe and only then lock down the plate. ^ this. leave the can installed then pump up the can till the rotor phasing is dead on & drill down thru both both plates for a small bolt/spacer/nut install to lock it in that position then take it apart & clean it up & go back together.
