Re: Isky adj rockers
[Re: parksr5]
#3013838
02/09/22 07:19 PM
02/09/22 07:19 PM
Posts: 43,099 Bend,OR USA
Cab_Burge
Sold already. Don't know why I even looked, I just bought another set last week. Figured, hey, if they're like $200 or less, a third set couldn't hurt. Those were not the good Isky rocker arms tsk: They looked like the Erson, Cranes and other companies that sold that particular manufacturer that made and sold those cheaper rocker arms to any cam company or anyone else that wanted to buy them in large quantities The good Isky had heat treated wear tips welded on the valve stem ends, the main bodies are wider also
[Re: jvcuda]
#3013970
02/10/22 10:00 AM
02/10/22 10:00 AM
Posts: 8,853 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
These are the rockers from that ad. You can clearly see the hardened pad - which they all have and is clearly visible in the original ad. Sometimes a good deal is just a good deal !!!
[Re: Stanton]
#3014078
02/10/22 04:36 PM
02/10/22 04:36 PM
Cab_Burge
Do all of the rockers have those welded on wear tips? Some of those rockers look like the good Isky and the rest don't: confused:
[Re: Cab_Burge]
#3014114
02/10/22 06:12 PM
02/10/22 06:12 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
If you zoom in you'll see very clearly that the pads are visible eleven of them. No reason to doubt they all have them. FWIW I have never seen an Isky that didn't have the pads. Cranes didn't and I wouldn't take a set of those if someone gave them to me!
