Vaccuum advance cannisters #3012979
02/07/22 11:20 AM
02/07/22 11:20 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Is there much difference in the amount of advance, the curve, provided by different cannisters ?
I have never come across a chart with different vaccuum can part numbers, or how much advance they give.
I'm interested in BB distributors, typical 60's / 70's stuff, or if there are any specialty aftermarket cans.
Re: Vaccuum advance cannisters [Re: hemienvy] #3012982
02/07/22 11:23 AM
02/07/22 11:23 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
IIRC the FSM's have the advance numbers for the vacuum advance.
Re: Vaccuum advance cannisters [Re: 6PakBee] #3012985
02/07/22 11:30 AM
02/07/22 11:30 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The standard motors E catalog generally lists the amount of advance on their stuff.
Re: Vaccuum advance cannisters [Re: Sniper] #3012988
02/07/22 11:35 AM
02/07/22 11:35 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Here's a link from another site that shows how to limit the amount of advance using a wire or sheet metal clip placed on the canister arm.
https://www.forabodiesonly.com/mopar/ams/how-to-limit-and-adjust-chrysler-vacuum-advance-cans.183/
Re: Vaccuum advance cannisters [Re: mrob] #3013011
02/07/22 12:48 PM
02/07/22 12:48 PM
VA
dragon slayer Offline
VA
Dual Point or Normal. Prestolite have arm # stamp and curve data in their book. Adjustable via shim washers and or spring. Newer mopar types have adjustable screw to help with curve. As stated the FSM also some info on this. G
Re: Vaccuum advance cannisters [Re: dragon slayer] #3013037
02/07/22 02:14 PM
02/07/22 02:14 PM
moparx Online content
moparx  Online Content
the adjustment is a 3/32" allen wrench inserted into the hose nipple.
i' can't remember [really ? what a surprise ! laugh2] which way turned increases or decreases the amount of vacuum needed to start the arm actuation.
that could be confirmed by using a hand held vacuum pump, and watch what amount of vacuum it takes to start the arm to move.
beer
Re: Vaccuum advance cannisters [Re: moparx] #3013183
02/07/22 09:25 PM
02/07/22 09:25 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
they do vary. some will have different number of degrees in them and different spring rates.
Re: Vaccuum advance cannisters [Re: lewtot184] #3013337
02/08/22 01:21 PM
02/08/22 01:21 PM
correct Lew.
that is another way to tailor the advance curve.
this is where "try it and see what happens" comes into play.
most of the time, a super tune is not done in one 20 minute period.
just because your buddy runs advance can #xyz, doesn't mean it is the right can for your combination.
it may be CLOSE, but not necessarily right ON.
i think it's member Cab Burge that says : "tune, tune, and tune some more". up
lots of things to consider to get the most from your particular combination.
beer
Re: Vaccuum advance cannisters [Re: moparx] #3013416
02/08/22 04:07 PM
02/08/22 04:07 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Originally Posted by moparx
correct Lew.
beer
up i agree. i can't count how many different distributor curves i've built for my two cars, plus all the hours and miles testing.
