Cleaning Silver Argent paint without damaging it #3012932
02/07/22 12:18 AM
02/07/22 12:18 AM
69x Offline OP
69x  Offline OP
I was checking out my 69 GTX that is put away for the winter, I lifted up the car cover and noticed one of the taillight bezels had some tan spots on the silver argent paint, I dabbed a little water on in with my finger and it helped a little but stopped as I found myself wanting to try and rub it out which in turn would remove the sandpaper like texture of the argent paint and the temp was only about 26F and the water froze on the argent and I did not want to discolor it.
So when it warms up is there a way to clean and remove the spots without removing the argent paint ? the bezel is nos and I hope I can get it looking good again. I think the tan spots were caused by Boxelder bugs doing whatever they do.
Thanks Moparts
Re: Cleaning Silver Argent paint without damaging it [Re: 69x] #3012934
02/07/22 12:52 AM
02/07/22 12:52 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I'd try something gentile like a soft paintbrush and some water or car detailing spray.
Re: Cleaning Silver Argent paint without damaging it [Re: Neil] #3012945
02/07/22 01:40 AM
02/07/22 01:40 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Old toothbrush and a mild mix of simple green.
If that doesn’t work. Try stronger concentration of simple green.
Re: Cleaning Silver Argent paint without damaging it [Re: autoxcuda] #3013021
02/07/22 01:16 PM
02/07/22 01:16 PM
moparx Offline
moparx  Offline
make sure the toothbrush is a "soft" one.
they come in soft, medium, and hard.
i have one of each, clearly marked, so i can pick the one i need for the job i intend to do.
beer
Re: Cleaning Silver Argent paint without damaging it [Re: moparx] #3013122
02/07/22 05:42 PM
02/07/22 05:42 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Soap and water, let is soak and let the soap do the work, don’t rub it very much or it will leave a spot.
Re: Cleaning Silver Argent paint without damaging it [Re: NANKET] #3013131
02/07/22 06:24 PM
02/07/22 06:24 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Should throw in camera lens brushes for being a good tool to use for delicate cleaning without scratching.
Re: Cleaning Silver Argent paint without damaging it [Re: 69x] #3013153
02/07/22 07:52 PM
02/07/22 07:52 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The original argent on the 1970 Sport Satellite here still looks amazing.
I wet copiously with a hose & dab it gently with a thick soapy sponge, no rubbing at all.
Then a liberal rinse with the hose.
