Re: 572 all aluminum headed to dyno
[Re: fbs63]
#3012429
02/05/22 11:50 AM
02/05/22 11:50 AM
Posts: 10,095 MN
JERICOGTX
MN
Looking forward to the results.
69 GTX
68 Road Runner
[Re: CokeBottleKid]
#3012543
02/05/22 06:17 PM
02/05/22 06:17 PM
Posts: 293 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Interested in the dry sump setup, any lifter valley scavenging? Any more pictures/details on the oiling system? Awesome engine!
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: fbs63]
#3012599
02/05/22 09:12 PM
02/05/22 09:12 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
[quote=B3422W5]Who specc’ed the cam? If Best Machine built it I'm betting they came up with the cam grind. [/quote I have had them do a motor and had the cam for it elsewhere... which I why I ask In my case I took Dwaynes recommendation
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: AndyF]
#3012712
02/06/22 11:59 AM
02/06/22 11:59 AM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Did the heads get 2.25” intake valves installed?
[Re: fast68plymouth]
#3012719
02/06/22 12:20 PM
02/06/22 12:20 PM
Posts: 31,203 Oregon
AndyF
Did the heads get 2.25” intake valves installed? Yes, heads were reworked to match this shortblock. Chambers opened up for the 4.50 bore size, 2.25 valves, etc.
[Re: EchoSixMike]
#3012869
02/06/22 08:55 PM
02/06/22 08:55 PM
AndyF
It seems like a small head for what otherwise seems a pretty aggressive setup, any reason why? S/F....Ken M It is what the customer wanted to do. It makes sense based on the customer's plan for his car.
[Re: AndyF]
#3012912
02/06/22 11:15 PM
02/06/22 11:15 PM
Posts: 6,163 Melbourne , Australia
LA360
I've not seen a duration split like that on a Big block, it's pretty common on high HP small blocks though.
Will be interesting to see the results
Alan Jones
[Re: JERICOGTX]
#3013024
02/07/22 01:30 PM
02/07/22 01:30 PM
Posts: 19,544 Las Vegas
Al_Alguire
Las Vegas
I have run exhaust splits that far many times on a BB. We have run as much as 16 degrees more on the exhaust side. Be screwing a new Predator together here soon and based on past experience it will have at least a 10 degree split(cam is the only thing we have not decided on yet). Expecting to to make 1130-40 with a very bracket friendly single 4 combo for stop racing.
[Re: 440Jim]
#3013056
02/07/22 02:49 PM
02/07/22 02:49 PM
Posts: 16,936 NC
440Jim
NC
Correct, Big EZ heads, 325 cc. Compression is 14.5, cam is 280/296 at 050. We'll run it with 2 inch dyno headers. Throttle body is a Holley 2000 cfm with a 4500 bolt pattern. Intake is a Super Victor fully ported by Wilson. T&D rocker arms, Callies crank, Callies rods, Jesel belt drive. Is it too early for me to guess 920 HP? But the small headers may reduce peak HP. Any other guesses? For the record, using those small headers I am subtracting 30hp. 890 HP with the peak below 7,000 rpm.
[Re: 440Jim]
#3013061
02/07/22 03:00 PM
02/07/22 03:00 PM
Posts: 10,095 MN
JERICOGTX
MN
Correct, Big EZ heads, 325 cc. Compression is 14.5, cam is 280/296 at 050. We'll run it with 2 inch dyno headers. Throttle body is a Holley 2000 cfm with a 4500 bolt pattern. Intake is a Super Victor fully ported by Wilson. T&D rocker arms, Callies crank, Callies rods, Jesel belt drive. Is it too early for me to guess 920 HP? But the small headers may reduce peak HP. Any other guesses? For the record, using those small headers I am subtracting 30hp. 890 HP with the peak below 7,000 rpm. I'll guess 904hp. Peak around 6700.
69 GTX
68 Road Runner
[Re: LA360]
#3013086
02/07/22 03:46 PM
02/07/22 03:46 PM
Posts: 10,088 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Will be interesting to see the results Indys suggestion to me for a 572-13 head on 550 cubes was 285/305/112 in at 108. Considering those heads come with a 1.88 exhaust valve, i was surprised . They also said max lift of . 825. I will make due with my 284/296/114 with . 868 gross intake lift. Considering lash etc i will be below . 848 net lift intake.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: JERICOGTX]
#3013134
02/07/22 06:31 PM
02/07/22 06:31 PM
AndyF
Correct, Big EZ heads, 325 cc. Compression is 14.5, cam is 280/296 at 050. We'll run it with 2 inch dyno headers. Throttle body is a Holley 2000 cfm with a 4500 bolt pattern. Intake is a Super Victor fully ported by Wilson. T&D rocker arms, Callies crank, Callies rods, Jesel belt drive. Is it too early for me to guess 920 HP? But the small headers may reduce peak HP. Any other guesses? For the record, using those small headers I am subtracting 30hp. 890 HP with the peak below 7,000 rpm. I'll guess 904hp. Peak around 6700. PipeMax says 904 hp too.
[Re: 440Jim]
#3013550
02/08/22 10:36 PM
02/08/22 10:36 PM
AndyF
Correct, Big EZ heads, 325 cc. Compression is 14.5, cam is 280/296 at 050. We'll run it with 2 inch dyno headers. Throttle body is a Holley 2000 cfm with a 4500 bolt pattern. Intake is a Super Victor fully ported by Wilson. T&D rocker arms, Callies crank, Callies rods, Jesel belt drive. Is it too early for me to guess 920 HP? But the small headers may reduce peak HP. Any other guesses? For the record, using those small headers I am subtracting 30hp. 890 HP with the peak below 7,000 rpm. We made a few pulls today. It made 870 power at 6800 and 760 torque at 5400. Found a few items to work on. Not sure if we'll put it back on the dyno or just make the changes and put it in the car. Depends on what the owner wants to do. No doubt in my mind that it would easily make 900 hp with some minor changes.
