Do the early roller blocks use the same spider type lifter retainer as the Magnum?
yes, same roller lifters/dogbones/spider.
PRs? I would have to check hollow & solid - LA & magnum. seems I have grabbed the PRs from a magnum for a LA roller conversion. and I have had engines oiling LA rocker shafts and oil thru lifter hollow PRs with no issues other than VC leaks if not sealed up good. ( I have plugged the hollow rods for less oil in VC area with good results)
unless you want to just "say" you have a roller cam engine don't waste time/effort/cash on running the stock roller cams they just are weak. smooth but weak.
just watch for early non-oil thru lifters if building a magnum engine.
I just got 16 NOS mopar roller lifter & PR packages dated 89 and they are oil thru with a solid PR. I have 2 or 3 sets on the shelf that are high mileage and still in good shape. I have salvaged many sets from JY engines and have found many clogged/stuck/carboned up. disassemble them on the bench and clean/oil them up and run them. the sets on my shelf I will most likely not use again as I know they were around 100,000 when I got them from a JY and run them for yrs and now have 250.000 to 300,000+ street duty daily traffic use the last 25 yrs.
I trust OEM used rollers over a new china made one over the counter right now.
so far I have run up to .500 lift/comp 901 springs all stock LA engine non-adjustable valve gear with yrs of street duty. my oldest Hughes roller cam is 07' with 250,000+ miles in its 4th engine 3 different used roller lifter sets. LOL! now that's bang for my buck when I thought the 700$ upgrade/conversion to LA-pre-magnum roller cam engines from the flat tappet cams back in 07' was a lot of cash. 500$ for cam/springs and 200$ for JY high mileage roller cam & valve gear.
disclaimer is/was - Hughes did say they had no knowledge of the magnum cams in a pre-mag engine and would not recommend it or the use of comp springs or warranty if I had issues... wonder what they say now?
glad I rolled the dice and had the learning curve. now I own several of the Hughes steam roller & whiplash roller cams in LA-roller cam 318s and have run both small & large LA heads with great results.
