Re: Reverse manual valve body pros and cons [Re: moparx] #3014179
02/10/22 10:55 PM
02/10/22 10:55 PM
Do you remember the name "nuetral starts" also? shruggy
I do and if my memory is correct the picture your talking about was caused by a "neutral start" scope
Re: Reverse manual valve body pros and cons [Re: moparx] #3014192
02/10/22 11:51 PM
02/10/22 11:51 PM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by moparx
Originally Posted by John_Kunkel
Originally Posted by Cab_Burge
727 started exploding when trans brakes were invented and installed twocents scope
TF's were exploding long before anybody ever heard the term "transbrake".
i remember the famous picture of the 64 dodge pushed back, exposing a "few" expensive parts on the ground covered in transmission fluid. shock
that was a ways before transbrakes were invented.
beer
And it had the rear band on in low too.
Re: Reverse manual valve body pros and cons [Re: Cab_Burge] #3014348
02/11/22 02:15 PM
02/11/22 02:15 PM
moparx Offline
moparx  Offline
oh yes ! we called them "neutral drops" around here. it's amazing none of us got out feet blown off, as many as we did growing up ! shock
and there was also what we called "J-Hooks", where we would go as fast as we could in reverse, then jam it into low !
the longest "Hook" was the winner. or "wiener", thinking back on it now......... laugh2
and i believe you are correct about that picture being caused by a neutral drop or start.
beer
Re: Reverse manual valve body pros and cons [Re: Cab_Burge] #3014419
02/11/22 05:00 PM
02/11/22 05:00 PM
A727Tflite Offline
A727Tflite  Offline
The driver never did neutral drops. Ever.
Didn’t have to. Car ran more than 4 tenths under the record.
More internet B.S.
Re: Reverse manual valve body pros and cons [Re: A727Tflite] #3014500
02/11/22 08:17 PM
02/11/22 08:17 PM
I've seen cars (of all brands, not just Mopars) due neutral drops or starts at Orange County drag strip, the old Irwindale 1/4 mile strip. The first time i saw was at Mickey Thompson Fontana Drag City in Fontana, CA in 1964. work
Have you seen the picture of the AA/Fuel altered dropping, blowing, the complete crank assembly and the bottom of the block out of a early blown fuel Chrysler firepower hemi at Orange County drag strip in the late 1960s
I wish I had found and bought a copy of that one, but I didn't realcrazy
it was an excellent picture, you could see the oil coming down with the parts. I was told it had a clucthflyte in the car also, you could see the flywheel on the back of the crank also shock: work:
Re: Reverse manual valve body pros and cons [Re: Cab_Burge] #3014505
02/11/22 08:30 PM
02/11/22 08:30 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
BBC
Re: Reverse manual valve body pros and cons [Re: A727Tflite] #3014671
02/12/22 12:45 PM
02/12/22 12:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
But burnouts in 1st gear were common then with no LBA. Same possible result.
Re: Reverse manual valve body pros and cons [Re: John_Kunkel] #3014675
02/12/22 01:00 PM
02/12/22 01:00 PM
A727Tflite Offline
A727Tflite  Offline
The biggest contributor to ORC failure is roller spit back under power.
The other contributors are cam movement in the case, excessive race to drum clearance/runout, excessive drum to support clearance/runout.
