What radiator hoses ?? #3010168
01/29/22 04:06 AM
01/29/22 04:06 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
I have a 71 charger that I need to buy a correct ish. Upper n lower radiator hoses for
None of this is orignal so don't know what year/car I need to asking for at parts store
It now has a mid 70s big block with lower hose on passenger side
Top will be on driver side
I bought a champion radiator that has the outlets to match
Reason asking is I don't know what side they were on a big block in 71. And I can't remember if at some point
I changed the water pump housing and I hate the one flex hoses
Thank you in advance
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: What radiator hoses ?? [Re: toplescuda] #3010201
01/29/22 10:38 AM
01/29/22 10:38 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Looks at hoses for a small block and trim to fit
Re: What radiator hoses ?? [Re: toplescuda] #3010253
01/29/22 01:43 PM
01/29/22 01:43 PM
Does your car have air conditioning? The hoses are different for them, try and buy them for a 1973 B. B. Body car scope
I'm sure Mopar swap to the passenger side lower hose in 1972 or 1973, 1971 would have been on the driver side for the lower hose twocents
Re: What radiator hoses ?? [Re: Cab_Burge] #3010272
01/29/22 02:20 PM
01/29/22 02:20 PM
moparx Offline
moparx  Offline
i keep around one of those universal "chrome" like flexy hose type things that go from the air cleaner snorkel to the tin heat stove on the exhaust manifold.
the universal types are pretty long, and when i need a particular hose shape, i will form that thing into position, then go to the parts store and look at the hoses on the wall to see if there is something close to the shape i have formed.
those things work pretty good for this.
when done, i straighten it out, push it back together, and put it back into the package for the next time.
beer
Re: What radiator hoses ?? [Re: moparx] #3010335
01/29/22 05:29 PM
01/29/22 05:29 PM
BDW Online content
BDW  Online Content
What application was the Champion radiator, that should tell you what hoses works.
Re: What radiator hoses ?? [Re: BDW] #3010417
01/29/22 11:10 PM
01/29/22 11:10 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Don't think it had a app. Just stated what side each outlet was on
So the lower hose. I can order one for a 73. With a 400 and il be good there correct
1971 charger
Re: What radiator hoses ?? [Re: toplescuda] #3010543
01/30/22 01:58 PM
01/30/22 01:58 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
mancini's has a pretty good selection of rad hoses
https://www.manciniracing.com/radiatorhoses.html
Re: What radiator hoses ?? [Re: Dodgem] #3010553
01/30/22 02:46 PM
01/30/22 02:46 PM
5thAve Offline
5thAve  Offline
Did the locations on them change much? On the small block stuff it was usually the same and the main difference was length of hose and diameter depending on application. Bigger diameter was mainly truck stuff.
Re: What radiator hoses ?? [Re: 5thAve] #3010654
01/30/22 08:17 PM
01/30/22 08:17 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Well bought a small block upper. Had one bend from coming out water neck. Rest was straight. Well that didn't work as it pinches off to get on radiator. So order one off rock auto. I could actually see what it looked like and I think will work
Bottom I ordered for a 73 charger with a 400
1971 charger
Re: What radiator hoses ?? [Re: toplescuda] #3010655
01/30/22 08:20 PM
01/30/22 08:20 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
What I have going on
1971 charger
