gluing in lexan polycarbonate window
#3008333
01/23/22 09:26 PM
01/23/22 09:26 PM
Posts: 482 Michigan
BigFish69
has any one glued lexan polycarbonate window in instead of screwing it, if so what adhesive did you use.
Re: gluing in lexan polycarbonate window
[Re: BigFish69]
#3008432
01/24/22 08:58 AM
01/24/22 08:58 AM
Posts: 9,963 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I wouldn't be willing to try it till I new it is being used in Pro Stock or similar classes. Call some of the big chassis builders to seek the best guidance on how to install.
[Re: dvw]
#3008460
01/24/22 11:26 AM
01/24/22 11:26 AM
Posts: 1,599 westerly, ri. usa
440lebaron
westerly, ri. usa
3M urethane windshield caulking, used in OEM good till 170 mph, glass needs to be molded to shape (curve)
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: DoubleD]
#3008490
01/24/22 01:09 PM
01/24/22 01:09 PM
Posts: 2,094 Byron, NY
W.I.N. Racing
Byron, NY
Yes Optic Armor provides it with it molded windshields.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: fbs63]
#3008867
01/25/22 02:43 PM
01/25/22 02:43 PM
Posts: 19,239 north of coder
moparx
this question has rattled around in the cobwebs of my noggin for a long time, so i guess this is as good a time as any to ask. supposing i am correct in assuming [you know what that means. ] new vehicles use the glued in glass as a somewhat structural enhancement, just exactly how much enhancement is this worth, and is lexan or it's newer, stronger versions [or maybe just different names, i don't know], somewhat comparable ? if this a stupid question, i apologize in advance...........
[Re: BigFish69]
#3009040
01/25/22 11:41 PM
01/25/22 11:41 PM
Posts: 18,389 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
My experience is it will not last. I have heavy equipment that have glass of poly and other compositions. They set and work well until time takes over. The glass will release from the adhesive. Not today but wait and see.
[Re: NITROUSN]
#3009210
01/26/22 02:15 PM
01/26/22 02:15 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
FWIW it is NOT a new practice, been going on for years. It definitely seems to be better suited to molded lexan than flat sheets in the windshield.But it works with flat sheet as well as long as the windshield does not have a complex curve to it. I have gone back and fourth in my Dakota, stock windshield, lexan bolted or lexan bonded. It previously had lexan with 88 screws, yes 88! So I dont really want to use screws as that's to many and the screws used were to large. Also I cannot use a machine screw and nut which I would prefer to use. So I think I am going to "glue" it in and see hoe it goes. No one makes a molded windshield for a Dakota. But it is a gentile curve so we will do our best and see it goes. FWIW I have used molded front and rear glass many times and had it simply held in with factory gaskets and never had an issue. Of course I only went 170MPH that way. The truck should be able to achieve similar MPH all out when done so we shall see.
[Re: A/MP]
#3009993
01/28/22 03:24 PM
01/28/22 03:24 PM
Posts: 200 Texas
Chief
Texas
Has anyone thought about using the double sided tape that is used on screw less trailer panels? Just had that thought while reading this. Not sure if it can be bought in different thickness.
Dave Covey
[Re: BigFish69]
#3010239
01/29/22 01:10 PM
01/29/22 01:10 PM
Posts: 200 Texas
Chief
Texas
Thought about it just wasen't sure it would hold, Is that what they use on trailers seem like pretty big panel to be held on by tape ? It is supposed to be some special tape, made by 3M I believe. lot of prep work compared to rivets or screws. They have been doing it for years and it holds up well. I have however seen a few trailers where it stopped holding. I have a friend in Waco who re skinned his 32 foot tag and he went screwless, he said it was a pain in the rear for him but he was doing it with the walls vertical. Trailer did turn out nice. I haven't checked but I'm curious as to there are different thickness of the tape. Dave EDIT: I just checked and it comes in .045 (45 mil) or .062 (62 mil). 3 M brochure
Dave Covey
