Re: Too light front weight! Where do I start? (Susp setup)
[Re: gregsdart]
#3009145
01/26/22 11:45 AM
01/26/22 11:45 AM
Posts: 4,758 Moved to N.E. Tennessee
GomangoCuda
Watch your video and then watch Al's Vette video. What I see is you have short flexible wheely bars set pretty high off the track and a lot of front end separation. Al has long stiff bars set close to the track and very little front end separation. Al's is like a prostock with little to no pitch rotation and yours is set up more like a super stocker that needs pitch rotation. Keep in mind that super stock is like a bracket race. They want to stick the tires for consistency but in heads-up classes they need wheel speed and black tracking to get the quickest E.T. That said, tie down the front end, get 4 really good shocks and better wheely bars and you are there.
[Re: GomangoCuda]
#3009189
01/26/22 01:51 PM
01/26/22 01:51 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Might also look at removing some weight out back. See what you can do without. You only need enough support to hold the body in pace behind the rear end.
[Re: gregsdart]
#3009305
01/26/22 04:41 PM
01/26/22 04:41 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My wheelie bars are actually 66 inch long. Solid, but may go to a rather stiff spring to soften the transition. In the slow mo video i had them as high as they will go for a little fun and show.
[Re: gregsdart]
#3009462
01/27/22 12:26 AM
01/27/22 12:26 AM
Posts: 6,149 Melbourne , Australia
LA360
What about doing an Ultralink type set up Greg? Not sure if anyone remembers those? not sure what that is? Hodge Motorsports used to make them. Basically a swing arm and upper bars in place of a ladder bar. I don't think they really caught on though, as I don't think they're still made.
Alan Jones
[Re: gregsdart]
#3009492
01/27/22 07:25 AM
01/27/22 07:25 AM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Both, springs are cheep. Easy to change. And have a big impact.
When I went aluminum block I had to add a hole to my front 4-link bracket.
[Re: FastmOp]
#3009531
01/27/22 10:45 AM
01/27/22 10:45 AM
gregsdart
When I went aluminum block I had to add a hole to my front 4-link bracket. Sounds like it had a huge effect?
