Page 2 of 3 1 2 3
Re: Copper in oil filter [Re: fast68plymouth] #2963322
09/12/21 06:03 PM
09/12/21 06:03 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Originally Posted by fast68plymouth
Originally Posted by Wirenut
So when I had the gear out today I put some ot the debris chips next to it and they don’t look to be the same color . The debris looks copper to me
I think you know what that means.
Although, the bushing is usually more copper colored than the gear.
See if you can get a measurement of how thick the flange on the bushing is, and compare to a new one to get an idea of how much is worn off it.
Like measure the oil slot or remove the bushing?
Re: Copper in oil filter [Re: Wirenut] #2963325
09/12/21 06:04 PM
09/12/21 06:04 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Is there or should there normally be a steel washer under the gear? Could I have missed it in the rebuild? And if I did would it take this long to show itself?
There was never a washer or shim supplied or suggested. HOWEVER, back in the day roller cams were seldom used in anything but a race motor that saw regular teardowns or maintenance. Subsequently wear was likely caught in the early stages and the gears swapped out before any significant damage occurred. However, once rollers started seeing more street use and probably less maintenance, its become an issue. But one that's easily solved or avoided. Either with a steel shim or a treated steel gear.
Re: Copper in oil filter [Re: Stanton] #2963379
09/12/21 08:02 PM
09/12/21 08:02 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
In my experience the washer works. Zero wear after installing a washer. Same gear at 750 passes.
Doug
Re: Copper in oil filter [Re: dvw] #2963411
09/12/21 09:03 PM
09/12/21 09:03 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks guys.
Pretty sure that what’s in the filter is copper . Doesn’t seem the large amount of debris equals the wear on the gear or bushing.
It’s going to have to wait until winter . I have a lot on my plate right now.
Re: Copper in oil filter [Re: Wirenut] #2963438
09/12/21 10:26 PM
09/12/21 10:26 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Bearing. Got through the bearing surface and into the copper intermediate layer.
Re: Copper in oil filter [Re: Wirenut] #2963479
09/13/21 01:30 AM
09/13/21 01:30 AM
Boise
Moparteacher Offline
Boise
Larry Shepard (formally Hemis Only) offers the modified intermediate gear with the torrington installed. 330-644-2000.
http://hemisonly.com/index.html
Re: Copper in oil filter [Re: Moparteacher] #2963497
09/13/21 07:55 AM
09/13/21 07:55 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Sorry to say but most likely, thats bearing material.
IF the oil pressure is good and really hasnt changed, check the endplay on the crank. Might be knocking the thrust bearing out.
....BAD A$$ STREET CAR.....
Re: Copper in oil filter [Re: n20mstr] #2963521
09/13/21 09:39 AM
09/13/21 09:39 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Check the trust on the crank shaft. Todd
Re: Copper in oil filter [Re: n20mstr] #2963567
09/13/21 11:47 AM
09/13/21 11:47 AM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Only other thing in the engine that color.
Re: Copper in oil filter [Re: sasquatch] #2963578
09/13/21 12:14 PM
09/13/21 12:14 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
This would be my bet as well. A friend just experienced the same problem.
Ok
Re: Copper in oil filter [Re: sasquatch] #2963581
09/13/21 12:19 PM
09/13/21 12:19 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree scope up
Re: Copper in oil filter [Re: Cab_Burge] #2963771
09/13/21 07:27 PM
09/13/21 07:27 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
iagree scope up
My thought as well. Ran the daylights out of it the week before and op was good , so keeping my fingers crossed .
Like I said I have a heavy life load right now so hoping to get it in the garage end of October. I’ll be updating then .
Thanks for the interest. Stay tuned
Re: Copper in oil filter [Re: Wirenut] #3006934
01/19/22 07:56 PM
01/19/22 07:56 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
iagree scope up
So finally got the engine out and yes it is the thrust bearing . Unfortunately it damaged the rear (front facing) thrust surface on the crank . Fortunately everything else looked very good. I dropped the crank at the machine shop today that is helping out with things and he informed me that part of repairing the thrust surface will be having to cut the mains down . Not happy about it but so far folks are telling me its not a big deal and wont really effect anything . The crank will be magnafluxed , the rod journals will be checked and checked for straightness.
I have searched threads here to shine light on what happened and most threads indicate trans / converter / trans pressure issues . The trans will go out next and cooler and lines will be checked.
Is there any way looking at a converter to tell if it has ballooned?
Am I missing anything?
FYI
This happened after about 80 passes . Previous rebuild was at 125 passes and all bearings including thrust surfaces looked great . The 125 passes were with King HP bearings at .003 . The 80 passes were with King XP also at .003 clearance .
Thanks Moparts
Re: Copper in oil filter [Re: Wirenut] #3006940
01/19/22 08:00 PM
01/19/22 08:00 PM
Definitely have the converter looked at for ballooning by really good converter company up, that is the only thing I can think of that would cause the thrust getting eaten up while running scope
What brand and size converter?
On the crank thrust I have had to have them welded up and reground to get the clearance correct and grind the mains down to the next under size to get the crank straight. :weldwrench
Re: Copper in oil filter [Re: Cab_Burge] #3006970
01/19/22 09:09 PM
01/19/22 09:09 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks Cab
Converter is very old . Not sure of manufacture. I would have to look back at some records from the previous owner . Memory is tci 5400 stall . I’m thinking time for a new converter
Gary
Re: Copper in oil filter [Re: Wirenut] #3006999
01/19/22 09:57 PM
01/19/22 09:57 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Check the thrust surface, it should be free of any scratches. Put a tee fitting in the to cooler line and see what the pressure is. 30# comes to mind. I’d flush your cooler too. What size cooler lines are you using.
Re: Copper in oil filter [Re: rickraw] #3007181
01/20/22 01:38 PM
01/20/22 01:38 PM
moparx Offline
moparx  Offline
if the crank needs welded up, maybe time for a stroker kit ? shruggy
beer
Re: Copper in oil filter [Re: moparx] #3007203
01/20/22 02:07 PM
01/20/22 02:07 PM
beer
devil up scope
Re: Copper in oil filter [Re: Cab_Burge] #3007228
01/20/22 02:59 PM
01/20/22 02:59 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Is the gold dust magnetic? That will tell you if it's engine bearing material.
Re: Copper in oil filter [Re: Cab_Burge] #3007375
01/20/22 08:56 PM
01/20/22 08:56 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
beer
devil up scope
It is a eagle stroker. The repair is $300.00 .
Page 2 of 3 1 2 3
