Page 2 of 4 1 2 3 4
Re: Are all 6 pack cams low taper design? [Re: cudaman1969] #3006655
01/19/22 12:59 AM
01/19/22 12:59 AM
A727Tflite Online content
A727Tflite  Online Content
Originally Posted by cudaman1969
Flat faced lifters.. goes against saying lifters have to have a crown don’t it.
They are not flat, wrong description.
Edited - they appear to be perfectly flat - at least to the naked eye after checking some that I have.
Re: Are all 6 pack cams low taper design? [Re: A727Tflite] #3006704
01/19/22 08:03 AM
01/19/22 08:03 AM
VA
dragon slayer Offline
VA
The TSB says the cam is low taper, it says the tappets are flat faced?
Re: Are all 6 pack cams low taper design? [Re: 6PakBee] #3006705
01/19/22 08:27 AM
01/19/22 08:27 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
Originally Posted by 6PakBee
I've never seen any reference that stock B or RB engines in any configuration used a Hemi valve spring. shruggy
6-paks had street hemi springs. they had a yellow stripe vs the hipo wedge being all red. they were a high rate spring which was common back in the day. actually a fairly crummy spring but we used them not knowing better.
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006706
01/19/22 08:36 AM
01/19/22 08:36 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i can't imagine any flat tappet cam lasting more than a few minutes without some taper. the low taper was to carry the extra spring pressure. this is one reason for the better rocker arms too. i remember back in the day busting so many of the 1968 rockers that i'd carry a small bag of them in the trunk. 6-paks had chrome stem valves too. factory wedge valves weren't very good for abuse so the chrome stem helped but didn't solve the erosion at the top of the stem were the rocker made contact. eventually the chrome stem and hardened tip ended most of those problems.
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006707
01/19/22 08:50 AM
01/19/22 08:50 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The factory parts manual will show the part numbers used, that would be the reference needed. Looking at my manuals I see the following.
1969
Hemi - 2899549
6bbl - 3418491
1970-71
Hemi - 3418491
6bbl - 3418491
So the answer is both yes and no. In 69 the 6bbl did not use the Hemi springs, in 70-71 they did.
Re: Are all 6 pack cams low taper design? [Re: Sniper] #3006709
01/19/22 08:59 AM
01/19/22 08:59 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
1969
Hemi - 2899549
6bbl - 3418491
1970-71
Hemi - 3418491
6bbl - 3418491
i suspect there may have been a manufacturer or supplier change for the part number change. original single street hemi springs had the yellow stripe and at some point later they were a green stripe. so there was a change and the 34xxxxx number tells me sometime after 1970. the 28xxxxx number would be correct for '68 and '69. anyhow i have some yellow and green stripe springs and the wire size, height, and spring rate are the same. i remember buying this stuff back in day but that's been so many decades ago.
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006711
01/19/22 09:11 AM
01/19/22 09:11 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
All I can say is that the 4bbl 440 used a different part number spring, same as the 383's did in 69. In 70-71 they used one of two different springs, depending on application I suspect Magnum vs non-Magnum type differences here. No mentions in any of the springs listings of stripe colors so no help there.
Nowadays, there are better choices.
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006712
01/19/22 09:19 AM
01/19/22 09:19 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i just did a rough calculation on hipo wedge and street hemi spring rates. the wedge came out 270lb rate and the hemi about 350lb rate. actual numbers would need to be calculated using actual real world springs but hopefully you folks get the idea.
i just dug up some spring info i done some time back. hipo wedge spring i checked was 100lbs@1.900", 238lbs@1.400". street hemi 95lbs@1.900", 300@1.400". noticeable difference in rate. both springs coil bind rather quickly with the dampner being the primary offender.
Re: Are all 6 pack cams low taper design? [Re: Sniper] #3006713
01/19/22 09:24 AM
01/19/22 09:24 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the non-hipo 256 cam did use a different spring. most i've seen were painted a greenish color and i think may have had an extra 1/2 or maybe 1 coil. the hypo wedge has,IIRC, an extra coil than the street hemi. factory cams back then had very mild ramp speeds and long closing ramps which didn't need a lot of spring. they were only 4500rpm engines.
Re: Are all 6 pack cams low taper design? [Re: 3hundred] #3006717
01/19/22 09:47 AM
01/19/22 09:47 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Okay, I am going from memory so take this all with a bag of salt. The standard 440 valve gear was good for about 5800 rpm. Chrysler wanted to raise this to about 6200 rpm. So they installed heavier springs on the Six-Pack motors. Heavier spring...more cam load....a low taper lobe provides more contact area and maintains engine durability with the higher loading. Again, I'm going from memory and I only have two functioning brain cells left.
If yours are gone, mine are too. It was also the rationale for the HD rocker arms which Direct Connection later claimed they'd reinforced the wrong end, FWTW.
From this thread I assume low taper lifters are made of unobtainium? Which would make an NOS 6 pack camshaft a paper weight?
It's no paper weight, just use the crowned lifters with it (new). Break it in normally and use a zinc oil, good to go.
Re: Are all 6 pack cams low taper design? [Re: GODSCOUNTRY340] #3006725
01/19/22 10:20 AM
01/19/22 10:20 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Does anyone have a pic of the six pack rocker arms vs the non-six pack rockers? Is there a part number stamped in them for identification purposes?
Re: Are all 6 pack cams low taper design? [Re: Sniper] #3006733
01/19/22 10:52 AM
01/19/22 10:52 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
1969
Hemi - 2899549
6bbl - 3418491
1970-71
Hemi - 3418491
6bbl - 3418491
Excellent research. Since I have an A12 I frequently find myself restricting a Six-Pack discussion to 1969 which can be, as it is in this case, a mistake. Thanks for the clarification.
Re: Are all 6 pack cams low taper design? [Re: Cuda340] #3006737
01/19/22 11:00 AM
01/19/22 11:00 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
think the "6pak rocker" was standard on 4bbl engines. my '69 r/t (4bbl) has the original rockers on it and they are the improved version vs the '68 and earlier. i don't have any original '68's but do have mopars re-pops and there is a noticeable difference. i'll try get some pics of the two later. the later rocker was used on '70's smog engines too so you're not boxed in by "6pak specific".
Re: Are all 6 pack cams low taper design? [Re: 6PakBee] #3006745
01/19/22 11:35 AM
01/19/22 11:35 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
1969
Hemi - 2899549
6bbl - 3418491
1970-71
Hemi - 3418491
6bbl - 3418491
Thank you. You know, looking at it again, the statement that the 6bbl never used the Hemi springs is correct. The Hemi, however, started using the 6bbl springs in 70-71. Semantics? maybe, but interesting.
As for rockers, when I converted my 64 413 to 906 heads I also used the later style rockers and there was a noticeable difference in metal thickness. At least to the eyeball, if I ever measured it I have forgotten those numbers, that happened in 1988 so time erased those memories, lol. My 413 was a bit of an oddball. It was originally stamped with a T then over stamped with a V. Indicating, to me, it was a 63 413 put into a 64 model car. The casting number ended in 3200, 63, it had rocker stands, last used in 63, and 4 bolt valve covers, again last used in 63. I do not recall the SPD of that car, it may have been an earlier 64 MY one. Who knows.
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006756
01/19/22 12:07 PM
01/19/22 12:07 PM
central il.
second 70 Offline
second 70  Offline
central il.
1969
Hemi - 2899549
6bbl - 3418491
1970-71
Hemi - 3418491
6bbl - 3418491
The hemi changed from a flat tappet cam and lifters to a hydraulic setup in 1970. That's why the springs changed.
Re: Are all 6 pack cams low taper design? [Re: dragon slayer] #3006764
01/19/22 12:27 PM
01/19/22 12:27 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What I read too
Re: Are all 6 pack cams low taper design? [Re: cudaman1969] #3006765
01/19/22 12:29 PM
01/19/22 12:29 PM
I corrected my post, the lifters I have appear to be flat as described.
The cam they ran on (low taper lobes) have wear across the whole width of the lobe but has a higher wear pattern to one side.
I corrected my earlier post where I said the lifters were not flat.
Re: Are all 6 pack cams low taper design? [Re: A727Tflite] #3006771
01/19/22 12:56 PM
01/19/22 12:56 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the heavy duty so called 6pak rocker
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006772
01/19/22 01:00 PM
01/19/22 01:00 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the older '68 style rocker
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006774
01/19/22 01:02 PM
01/19/22 01:02 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
street hemi springs on the left, yellow and green stripe. wire size, height, width, spring rate the same. spring on right is a magnum replacement (without red paint); same specs as stock 4bbl.
Page 2 of 4 1 2 3 4
