Anyone ever use these brakes? #300630
04/26/09 11:43 PM
04/26/09 11:43 PM
Dixon, CA
SuprB70 Offline OP
Raisin
SuprB70  Offline OP
Raisin
Dixon, CA
http://www.praisedynobrake.com/index.htm
I'm thinking about using them on my charger(the stage-3 set up). I want to keep it as stock as possible.
My brake system needs everything and it looks like I can get everything in one kit.
Re: Anyone ever use these brakes? [Re: SuprB70] #300631
04/27/09 12:09 AM
04/27/09 12:09 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
for that kind of money I wouldnt do it,,,,, you cant beat useing the 73 and newer A body stuff.
I am truckless..
Re: Anyone ever use these brakes? [Re: 340SHORTY] #300632
04/27/09 12:19 AM
04/27/09 12:19 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
or a F/M/J disc swap
Re: Anyone ever use these brakes? [Re: SuprB70] #300633
04/27/09 06:24 AM
04/27/09 06:24 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Did you guys read that he wants to keep it stock? I'm assuming from that and the description of the kit that means 4 wheel drums. Maybe not optimum for hard core braking, but not every car needs that.
That being said, I'm not sure how original those drums or that master cylinder look. Maybe close enough or maybe not. Depends on wheter you're going for concourse correct.
Re: Anyone ever use these brakes? [Re: FuryUs] #300634
04/27/09 08:42 AM
04/27/09 08:42 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've used those shoes on 11" drums before. they like heat and don't work real good cold on a manual system. with a power brake booster they stop very good, better than discs i'm using on a 65 b-body, with no fade or lock-up.
Re: Anyone ever use these brakes? [Re: FuryUs] #300635
04/27/09 11:40 AM
04/27/09 11:40 AM
no, I read "as stock as possible" and those aftermarket pieces are further from stock than the suggestions made. Read the details of the adverts, it says the parts pictured may not be what you get.(more or less)
Re: Anyone ever use these brakes? [Re: nomore65BelvJim] #300636
04/27/09 01:31 PM
04/27/09 01:31 PM
Dixon, CA
SuprB70 Offline OP
Raisin
SuprB70  Offline OP
Raisin
Dixon, CA
Thanks for the info guys.
I know is a bit of $ of drums but I have a numbers matching 68 that I want to keep stockish.
(I want good brakes that work but look stock)
the pic on top of this page: http://www.praisedynobrake.com/prices looks like a mopar system. My charger has the same master cylinder and the fornt drums look the same I think im going to give them a call and see whats up.
