Dougs Headers D453 question for owners
#3004882
01/13/22 01:28 PM
01/13/22 01:28 PM
Posts: 1,024 Slidell, La.
doctor_mopar
Slidell, La.
I am considering using the Dougs headers on my 67 Barracuda the has the 74 A body spool mount K member . I understand from posts I have read that they will work with this K member . My question now is are the face of the flanges at the head flat ? I don’t like to use gaskets , and I prefer to install with high temp RTV. I have had great success on the flat flanges , but not as well when they have the raised bead . Also are the flanges 5/16 or 3/8 thick ? Have you had good experience with them ? Thank You !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Dougs Headers D453 question for owners
[Re: doctor_mopar]
#3004898
01/13/22 02:19 PM
01/13/22 02:19 PM
Posts: 15,752 north of coder
moparx
make sure to cut the flanges between each exhaust port, and drill one hole on each tube section two sizes larger than they are at present. this will make sure the pipes stay sealed, as it allows slight movement between heat up and cool down. i stole this idea from member Mr. P Body at least 15-20 years ago, and it just flat works, no matter what gasket or sealing goo a guy wants to use. this even works on the cheesy 1/4" flange tubes. of course you want to make sure the raised bead or flange itself is relatively flat. a light dressing with a belt sander or da sander will work for that.
[Re: doctor_mopar]
#3006017
01/16/22 08:15 PM
01/16/22 08:15 PM
Posts: 1,234 Columbus, GA
Michael Ecks
Columbus, GA
I have a set of D453s on my shop wall, never installed so I can't say what kind of luck with them.
They Mic out at around .400, so actually thicker than 3/8 but some of that may be the ceramic coating.
They do have a welded bead on the head mating surface. It is wide compared to other headers I've had, and looks like it was machined flat not just ground down.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: moparx]
#3006069
01/16/22 09:59 PM
01/16/22 09:59 PM
Posts: 26,855 Mardi Gras-Land
340SIX
Mardi Gras-Land
I saw a bunch of threads on 453 at Abodiesonly and they say thet work fine with what you have. I was looking as might swap to them from my Hooker Super Comp. For 2 reasons
1) The Hookers hang low and the 453 do not and still clear all.thr stuff. And 2) I do not like where the collectors end up.
I have looked and did not see how the 453 collectors are. Was hoping the collectors come out where the factory put the headpipes in the crewmember. As I want the pipes tucked in the same place they were with the manifolds with the Hookers you have to go low and put a Big Woop De Doo at the collectors Sorry if I highjacked your thread Ron.
