rustoleum hammertone spray can paint #3003830
01/10/22 02:49 PM
01/10/22 02:49 PM
moparx Online content OP
moparx  Online Content OP
what is the correct method to spray this paint, and have it come out like it is supposed to ?
i have tried this stuff using every way imaginable, even FOLLOWING the instructions to a T, and i just can't get the finish it is supposed to be.
not even remotely close !
does anyone else make a hammertone paint in a spray can ? [please don't say krylon - i HATE that stuff !]
TIA to those WAY smarter than me on this subject ! bow
beer
Re: rustoleum hammertone spray can paint [Re: moparx] #3003836
01/10/22 03:05 PM
01/10/22 03:05 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I used it once and ended up with a solid smooth color so was rather disappointed. Wonder if they have any how-to videos out there that help?
Re: rustoleum hammertone spray can paint [Re: Neil] #3003869
01/10/22 04:51 PM
01/10/22 04:51 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Make sure and shake the can well. Put it on wet and heavy. I used it on an old gas tank, after spraying it was spot on to original zinc plating. Very happy with the results.
Re: rustoleum hammertone spray can paint [Re: maximus] #3003881
01/10/22 05:31 PM
01/10/22 05:31 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I used it on an area near lower windshield area on valiant where old seal was leaky and seal made a mess after 50 years of abuse, it covered nicely .. now, just to get back to rattle canning the rest one of these months
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: rustoleum hammertone spray can paint [Re: moparx] #3004015
01/11/22 02:14 AM
01/11/22 02:14 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I've used it, didn't do anything special but shake and spray, and it looked good when done. I wonder if it has to do with the temperature/humidity etc. where you're using it.
Re: rustoleum hammertone spray can paint [Re: Exit1965] #3004056
01/11/22 09:18 AM
01/11/22 09:18 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
You have to put it down pretty heavy and wet for it to do the hammered thing, where it looks to be full of fisheye. I did my shop cabinets with it.
1969 Hemi Roadrunner 2nd owner
Re: rustoleum hammertone spray can paint [Re: 69hemibeep] #3004094
01/11/22 12:26 PM
01/11/22 12:26 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I used it on the dash of the '55 Plymouth. Texture came out great but the white didn't cover worth a crap. Had to stop, resand, use white primer, and start over.
Re: rustoleum hammertone spray can paint [Re: 71charger] #3004128
01/11/22 01:35 PM
01/11/22 01:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I've never had much luck with it. Laying it down heavy resulted in pinholes - not "fisheyes" ... pinholes. Most recently I haven't had any luck with "wrinkle" paint either. I suspect formulas have been changed to satisfy EPA regs.
Re: rustoleum hammertone spray can paint [Re: Stanton] #3004174
01/11/22 03:17 PM
01/11/22 03:17 PM
i have tried laying it on wet and heavy, but then you get runs on vertical surfaces.
i have shaken it six ways from sunday, made sure the temperature was 60 or higher with the item, as well as the outside temperature, and still no luck.
i'm almost ready to try a light mist of wd-40 on something as a test to see what that would do.
or just forget the spray cans and try the brush on stuff with a foam brush. shruggy
beer
Re: rustoleum hammertone spray can paint [Re: moparx] #3004175
01/11/22 03:22 PM
01/11/22 03:22 PM
tboomer Offline
tboomer  Offline
Bob...One of the guys in the race forum did his roll cage with the hammer tone and a foam pad. It came out great! wave
Re: rustoleum hammertone spray can paint [Re: tboomer] #3004180
01/11/22 03:31 PM
01/11/22 03:31 PM
thanks T ! i was trying to remember where i saw someone use the brush on stuff, and you reminded me where. bow
now all i gotta do is find it.........
beer
