Re: Oil tube block mod
[Re: Cab_Burge]
#3003989
01/11/22 12:07 AM
01/11/22 12:07 AM
Posts: 11,479 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Looks like they were minimizing the tube that was (is?) used in small block mods to bypass oil into the left galley in order to slow down the oil flow through the system and/or prioritize oiling to #1 main. Even though the big block system is plumbed differently. That was some 70s and 80s tech that I never got on board with. There are other, better ways to fix these.
If you're going to run a mechanical cam, the left galley should be made dry as it does nothing but oil the lifters. Bushing the lifter bores is almost a necessity for high RPMs and a good idea for everything else to control those 16 massive internal oil leaks.
[Re: VernMotor]
#3004279
01/11/22 07:36 PM
01/11/22 07:36 PM
Posts: 12,415 Kalispell Mt.
HotRodDave
Kalispell Mt.
Maybe they thought they needed to feed more oil to the lifters to keep the cam from going flat?
[Re: VernMotor]
#3004283
01/11/22 07:41 PM
01/11/22 07:41 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Not sure why you would want to do that. Most of us block it off so no oil gets there. But we run flat tappet cam. no reason to have oil there. More oil goes down to the mails and rods. Only reason to oil the lifters from the galleys, as opposed to bushing the bores, is if you are using hydraulics or oiling the heads through the pushrods. Can still be bushed and drilled instead of having those huge oil leaks.
[Re: HotRodDave]
#3004286
01/11/22 07:44 PM
01/11/22 07:44 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Maybe they thought they needed to feed more oil to the lifters to keep the cam from going flat? Not going to help unless you have EDM lifters. Still don't need those huge holes feeding that lifter.
[Re: CMcAllister]
#3004287
01/11/22 07:48 PM
01/11/22 07:48 PM
HotRodDave
Kalispell Mt.
Maybe they thought they needed to feed more oil to the lifters to keep the cam from going flat? Not going to help unless you have EDM lifters. Still don't need those huge holes feeding that lifter. Didn't say it would, just speculating on the thought process that went into that mod.
[Re: old_racer]
#3004304
01/11/22 08:21 PM
01/11/22 08:21 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I think they did it to get oil down to the mains quicker, on a stock motor the oil goes down the pass side crosses over in the back then runs all the way to the front on the dr side when it dead ends then the oil can be forced down to the mains, by filling the dr side with that tube as soon as the motor is started you don't have to wait for the oil to run it's normal course before feeding the mains. makes sense? The only thing fed from the left side on a BB is lifters. The theory is oil is rushing through the right side so quickly, as it has to feed the mains AND the left side from the end of the right galley, that the oil can't make the sharp turn to the main feed passages. My theory is, plug or drastically reduce all the dang leaks so the oil isn't rushing through the system, squirting out all over the place, and can keep the crank full and under pressure. High RPMs is where the issues show up.
[Re: VernMotor]
#3004456
01/12/22 09:14 AM
01/12/22 09:14 AM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
The guy has this block and a stock steel crank for sale for 2100.00 !! Seems high to me Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3004535
01/12/22 01:30 PM
01/12/22 01:30 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The guy has this block and a stock steel crank for sale for 2100.00 !! Seems high to me Gus The price or the seller? Or both? This may or may not have been involved before that price was set. Just sayin'
[Re: VernMotor]
#3004552
01/12/22 02:00 PM
01/12/22 02:00 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I don’t see any benefit to stealing oil from the main feed from the pump, before it even gets into the main gallery.......and sending it to the pass side lifter gallery.
I’m not seeing it benefiting any of the bearings.
More oil to the drivers side lifters....... for whatever that might be worth.
Maybe in some race application that required running hyd lifters, where they felt the oil supply to the drivers side was compromised and caused lifter bleed down issues at high rpm. Like NHRA Stock eliminator before the Schubeks came on the scene. Nowadays you can just run solids.
[Re: fast68plymouth]
#3004576
01/12/22 02:42 PM
01/12/22 02:42 PM
Posts: 25,720 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I don’t see any benefit to stealing oil from the main feed from the pump, before it even gets into the main gallery.......and sending it to the pass side lifter gallery. The mod sends it to the drivers side gallery.
#3004577
01/12/22 02:46 PM
01/12/22 02:46 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
However, the only thing being lubed from that galley is the lifters. 8 large leaks spraying oil that could be better used on the crank. Putting oil in at the end of the system there basically fills the galleries from both ends. Intended to stop the oil from flowing through and ensuring the entire system is consistently full and pressurized. Again, solid lifters or not oiling the top end through the pushrods, or oiling the heads externally, plug the left galley and make it dry, eliminating the problem. Using an internal auxiliary hose/tube can be beneficial, if the left galley is plugged and the oil is plumbed into the rear of the right galley, filling it equally from both ends.
[Re: John_Kunkel]
#3004586
01/12/22 02:59 PM
01/12/22 02:59 PM
fast68plymouth
So. Burlington, Vt.
I don’t see any benefit to stealing oil from the main feed from the pump, before it even gets into the main gallery.......and sending it to the pass side lifter gallery. The mod sends it to the drivers side gallery. Right...... typo on my part. Oil is diverted into the drivers side gallery from the main feed out of the pump.
#3004860
01/13/22 12:40 PM
01/13/22 12:40 PM
Posts: 1,602 westerly, ri. usa
440lebaron
westerly, ri. usa
i would just plug it, looks like it would be a big oil pressure loss, he may have had cam issues?
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#3004899
01/13/22 02:20 PM
01/13/22 02:20 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
i would just plug it, looks like it would be a big oil pressure loss, he may have had cam issues? Cam is oiled from the mains. 5 more big leaks.
