Re: Engine swap mounts
[Re: jsully]
#3003642
01/09/22 10:25 PM
01/09/22 10:25 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
I have a new in box schumacher kit in my warehouse somewhere but I'm not sure exactly what kit it is. Big block in a A body maybe but I'll find it and post the part number soon. Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: jsully]
#3003754
01/10/22 11:12 AM
01/10/22 11:12 AM
Posts: 1,771 Keymar, MD
DusterKid
Keymar, MD
I used the Trans-Dapt ones to install a 360 in my 1969 Barracuda that is an original /6 car. The fit and finish were fine.
[Re: jsully]
#3004035
01/11/22 03:47 AM
01/11/22 03:47 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Does anyone have an update on acquiring engine swap mounts? ( With Schumacher kits no longer available) I’m in need of a set to swap out a /6 in a ‘70 Dart to install a ‘70 318 engine. I found Trans-Dapt at Summit racing, but not sure if the Trans-Dapt brand are as high a quality as the original Schumacher mounts… As far I know Schumacher just changed of owner and they will be making their mount adaptors again soon
[Re: NachoRT74]
#3004158
01/11/22 02:47 PM
01/11/22 02:47 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
If anyone is in need, I have a 440 source package for 66-72 b and 70-74 e for bb swap to v8 k's. Nib. Could not use since the Indy block has Hemi style mounting. PM me if interested.
Carl Kessel
[Re: jsully]
#3021570
03/07/22 05:06 PM
03/07/22 05:06 PM
Posts: 5 Murrieta, Ca
Schumacher CS
Murrieta, Ca
Does anyone have an update on acquiring engine swap mounts? ( With Schumacher kits no longer available) I’m in need of a set to swap out a /6 in a ‘70 Dart to install a ‘70 318 engine. I found Trans-Dapt at Summit racing, but not sure if the Trans-Dapt brand are as high a quality as the original Schumacher mounts… Hey there! My name is Chris Field, new owner of Schumacher Creative Services. I also own MOTECH performance in Murrieta, CA. Just wanted to let you, and anyone else, know that Schumacher is back. We currently have that kit for your Dart in stock, part number is A67A6. They're available here: https://www.engine-swaps.com/products/67-72-a-body-s6-to-273-318-or-340-360-conversion-kitWe're working on getting everything back in stock. I've appreciated everyones patience! -Chris
Schumacher Creative Services Engine-Swaps.com
[Re: Schumacher CS]
#3022924
03/11/22 01:57 PM
03/11/22 01:57 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Does anyone have an update on acquiring engine swap mounts? ( With Schumacher kits no longer available) I’m in need of a set to swap out a /6 in a ‘70 Dart to install a ‘70 318 engine. I found Trans-Dapt at Summit racing, but not sure if the Trans-Dapt brand are as high a quality as the original Schumacher mounts… Hey there! My name is Chris Field, new owner of Schumacher Creative Services. I also own MOTECH performance in Murrieta, CA. Just wanted to let you, and anyone else, know that Schumacher is back. We currently have that kit for your Dart in stock, part number is A67A6. They're available here: https://www.engine-swaps.com/products/67-72-a-body-s6-to-273-318-or-340-360-conversion-kitWe're working on getting everything back in stock. I've appreciated everyones patience! -Chris Now that’s good news! Chris I hope you are advertising in the new stuff area of moparts and the general topics area too. Schumacher has been fantastic to work with over the years. Glad to see this company coming back online. Do the name proud.
I’m listening.
[Re: Big Bad Bee]
#3024011
03/14/22 05:40 PM
03/14/22 05:40 PM
Schumacher CS
Murrieta, Ca
Does anyone have an update on acquiring engine swap mounts? ( With Schumacher kits no longer available) I’m in need of a set to swap out a /6 in a ‘70 Dart to install a ‘70 318 engine. I found Trans-Dapt at Summit racing, but not sure if the Trans-Dapt brand are as high a quality as the original Schumacher mounts… Hey there! My name is Chris Field, new owner of Schumacher Creative Services. I also own MOTECH performance in Murrieta, CA. Just wanted to let you, and anyone else, know that Schumacher is back. We currently have that kit for your Dart in stock, part number is A67A6. They're available here: https://www.engine-swaps.com/products/67-72-a-body-s6-to-273-318-or-340-360-conversion-kitWe're working on getting everything back in stock. I've appreciated everyones patience! -Chris Now that’s good news! Chris I hope you are advertising in the new stuff area of moparts and the general topics area too. Schumacher has been fantastic to work with over the years. Glad to see this company coming back online. Do the name proud. I'll have to swing over there and make a post. I'm keeping all the manufacturing here in the USA, as well as spacing US made hardware where I can. Quality is of the utmost importance. 🙂
[Re: hemienvy]
#3024012
03/14/22 05:40 PM
03/14/22 05:40 PM
Schumacher CS
Murrieta, Ca
Chris, I take it that the shop is not in Seattle anymore ? Nope, we moved everything down to Southern California so I can keep it under one roof with my other shop. 🙂
