More about manual disc brakes #3003332
01/09/22 12:18 AM
01/09/22 12:18 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Car is 70 E-body.
OK, I have original 10-inch rear drums and I'm adding 73 A-body front discs.
Car has the original manual M/C right now.
I want to keep it as manual brakes, but I could change the M/C if necessary.
Which prop valve setup do I need ?
Which M/C do I need ?
Re: More about manual disc brakes [Re: hemienvy] #3003356
01/09/22 05:04 AM
01/09/22 05:04 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The reservoirs on a disc brake master cylinder are two different sizes, the one for the calipers is larger as it needs more fluid to work properly.
Put a disc brake master cylinder on it, from a 73 A-Body manual disc brake car.
It's what most people run using stock type parts.
Re: More about manual disc brakes [Re: SNK-EYZ] #3003373
01/09/22 09:16 AM
01/09/22 09:16 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i did the a-body manual disc conversion on a b-body. i ended up with a 1.03 master cylinder after trying a smaller .93. the car stops but not very well. to do it over again i'd never use a large single piston caliper. beware that some kits use a 2.74 piston for b and e bodies. i had to get rid of the 2.74 and go down to the 2.47 to help in stopping. i have another b-body with 11" drums and power assist and i'd never ever ever ever take those drums off for a disc conversion knowing what i know now. there is absolutely no comparison in stopping.
Re: More about manual disc brakes [Re: lewtot184] #3003379
01/09/22 10:03 AM
01/09/22 10:03 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Then you did something wrong.
I've done two a body disc conversions and both work properly. I'd venture to say thousands have been done and work fine. The factory did hundreds of thousands of these and they worked fine.
They key is to mimic the entire factory setup. Not mix and match and delete stuff you don't think you need.
Re: More about manual disc brakes [Re: Sniper] #3003381
01/09/22 10:14 AM
01/09/22 10:14 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i doubt it.
Re: More about manual disc brakes [Re: lewtot184] #3003612
01/09/22 09:30 PM
01/09/22 09:30 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Did you use a manual brake brake pedal and mount the master with the proper bracket or proper set of mounting holes on the firewall?
A manual brake pedal has a different mounting bracket, and has a different hole for the master cylinder rod to bolt to. That gives the manual brake pedal more leverage then a power brake pedal has. If you used a power brake pedal in a manual brake system, you can't apply as much pressure to the manual brake system that it needs. If you mounted the manual master on the same bracket a power booster mounts to, or in the same set of holes in the firewall the booster mounted to, you have compounded the incorrect pedal problem. There are two sets of holes (or indentions for a set of holes) in the firewall to mount either a bracket the booster, or to bolt the master to, the manual master goes in the upper set of holes on the firewall, and the master cylinder rod bolts to upper hole on the pedal.
I've done probably a dozen of these conversions over the years, never had a problem with the disc brakes being worse then the drums were. Gene
Re: More about manual disc brakes [Re: poorboy] #3003647
01/09/22 10:32 PM
01/09/22 10:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up iagree
Re: More about manual disc brakes [Re: hemienvy] #3003675
01/09/22 11:51 PM
01/09/22 11:51 PM
AndyF Offline
AndyF  Offline
Originally Posted by hemienvy
Car is 70 E-body.
Doctor Diff can provide you with what you need. All of my cars have been manual disc brake cars. They work great when you use the correct parts. If you have 15 inch wheels then you should use the 11.75 rotors rather than the smaller A body rotors. Swapping on the larger 11 inch rear brakes will also help. With manual brakes you need all the leverage that you can get.
Re: More about manual disc brakes [Re: AndyF] #3003680
01/10/22 12:24 AM
01/10/22 12:24 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I had a 71 Dart Swinger that the previous owner converted to the 73 and up discs. It was a manual brake car and stopped on a dime. No complaints at all for a setup based off factory parts. If you get the right parts it should be all good.
I ended up with a 70 Malibu 350 after that with 4 wheel power drum brakes and missed the brakes on the Dart right away. Had to adjust my driving and give myself more distance to stop as that Chevelle had horrible brakes in comparison.
Re: More about manual disc brakes [Re: Neil] #3003681
01/10/22 12:28 AM
01/10/22 12:28 AM
KY
65pacecar Offline
65pacecar  Offline
KY
I am running manual disc brakes on a 65 C Body Sport Fury, work perfectly.
Re: More about manual disc brakes [Re: 65pacecar] #3003732
01/10/22 10:25 AM
01/10/22 10:25 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Manual discs on my 65 B body for like 20 years now.Run a 70 C body disc master and a IIRC 5th ave PP valve.Stops great even at 120 at the strip.Rocky
Chrysler Firepower
