Re: Show me your hemi builds
[Re: Mally69]
#3003524
01/09/22 06:18 PM
01/09/22 06:18 PM
Posts: 702 Lake Villa Il
INTMD8
Lake Villa Il
Might be easier to start with, what do you want/what are your goals?
[Re: INTMD8]
#3003532
01/09/22 06:38 PM
01/09/22 06:38 PM
Posts: 92 PA
Mally69
PA
Thats the thing. I really dont know. I just want to build a hemi. I have 5 cars yet to restore after this 69 bee is done. There are so many options as far as which blocks to buy, which heads are better suited for the application there in. Between the indy and stage v lineup idk which route i wanna go yet. Fitting under the factory hood on the 68 charger will be mandatory unless i put it in the 68 Coronet RT i would use SIXPACK hood on that one. I only have 68 69 70 B bodys. I just want to see what everyone has. Just has to run on pump gas is the only other mandatory object.
[Re: Mally69]
#3003545
01/09/22 07:08 PM
01/09/22 07:08 PM
Posts: 10,115 A Red State
SNK-EYZ
A Red State
People need to know what you plan to do with the car (street, race, etc) to give you some idea what would be your best way to go. That's why he said Might be easier to start with, what do you want/what are your goals? A race build is completely different from a mild street build. Someone posting the info on a race build would be useless if it's just going to be a mild street car (resto style build).
[Re: Mally69]
#3003572
01/09/22 08:00 PM
01/09/22 08:00 PM
Posts: 11,894 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Go to one of the experienced Hemi builders. Blocks have been in short supply the last few years, so many of the latest offerings are new enough that not just everyone has experience with them. But, they will ask you some of the same questions that you are being asked here such as; budget? What amount of maintenance are you comfortable with? How much can your drive train handle? Do you have any traction problems with your current set-up? Etc........................
My 540 made 697 crank at break-in. World iron block, Eddy/MP heads ported by MCH, Landy rockers, Ray Barton reciprocating assembly and cam which is a fts. Indy dual port intake and ThumperDart'ed 1050 Dominator. 91 octane, starts, runs and drives great. Sounds and runs like a Hemi should without being too much of pain in the a$$. Has to have Cal-Tracs and drag radials, otherwise it is just plain dangerous with any throttle at all. And can be a handful even with them.
Master, again and still
[Re: Mally69]
#3003606
01/09/22 09:19 PM
01/09/22 09:19 PM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
Im pondering building a hemi for my 68 charger. If anyone can post their build info with hp torque numbers that be awesome. Just lookong for some ideas. Here is my 492 cuin Hemi. 10.5:1 CR, custom cam (I'd have to look up the specs when I get home) w/ TTi Headers, 3" exhaust. MP cross ram with twin 650 cfm carbs. I was targeting 600hp. Installed the engine but never took it to a dyno. Hell, I haven't even driven it enough to even get it dialed in yet. Maybe this year.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Mally69]
#3003629
01/09/22 09:48 PM
01/09/22 09:48 PM
Posts: 12,379 Taxes & Virus's R-US, NY
Dragula
605 Pump gas Hemi...840hp 750 torque
11:1 compression...750 lift cam....Iron Mega block, Indy HiPo heads...Holley 4500 Sniper...Thats about it.
[Re: Mally69]
#3003731
01/10/22 10:20 AM
01/10/22 10:20 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Nice build NitrousN, Going to be doing a similar build myself for my 71 GTX. 4.500 mega block 528ci stroker with MP2 aliminum heads. I'm impressed with your figures with a 4bbl intake! What size carb is that? 2200cfm Monster or a KING Cobra 4150 lol... The Cobra looks much bigger even though its a 4150 carb... GtxxJon UK.
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: INTMD8]
#3003738
01/10/22 10:36 AM
01/10/22 10:36 AM
Gtxxjon
Isle of Sheeps
I'm blown away with the whole thread! Attention to details is staggering... I'm not even gonna talk about your workshop/garage, its awesome...
[Re: Gtxxjon]
#3003746
01/10/22 10:48 AM
01/10/22 10:48 AM
Gtxxjon
Isle of Sheeps
Is this why hemi's are so hard to beat?
That little torque and rpm spike, right at the end, maybe timing?
[Re: Gtxxjon]
#3003757
01/10/22 11:16 AM
01/10/22 11:16 AM
INTMD8
Lake Villa Il
Haha, thanks! That blip at the end I believe is when it sent the alternator belt into low earth orbit. I was running a stock diameter lower pulley modified for the depth of the crank trigger.
I've since changed it to an underdrive lower so hopefully fixed that problem. (and maybe picked up a few hp)
[Re: Mally69]
#3003833
01/10/22 02:59 PM
01/10/22 02:59 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
I built a 572 C.I. pump gas street Hemi motor for a local customer for his 1971 Challenger, he will drive it to local cruise and car shows. I used a World block bored to 4.500 and a 4.500 stroke crankshaft, 10.8 to 1 compression, dual EFI throttle bodies on a Stage 5 single plane dual throttle body intake manifold FHO rocker arms, solid roller EFI street cam. Mopar 1970/1971 stock street hemi oil pan and pickup, Holley EFI and ignition. It made 799 HP at 6500 RPM, and it made 704 Ft. Lbs. from 3500 RPM to 732 peak torque at 5400 RPM with 732 Ft. lbs. with 705 Ft. lbs. at 5900 RPM on 91 octane CA pump swill. it should be a real hoot to drive on the street
[Re: Mally69]
#3003840
01/10/22 03:11 PM
01/10/22 03:11 PM
Posts: 17,801 S.E. Michigan
ZIPPY
S.E. Michigan
4.500" bore, 4.500" stroke, Circa 2008 Mopar Performance/World block, K1 crank, Molnar Rods, Diamond pistons, Victor Jr. Heads, Crane .640 Mechanical street roller, I've got a few intake manifolds to try on it later/the one in the pic was just the first in line to try. Balanced by Best Machine in MI, assembled by me. Fired on 4/26/20 just to hear it and check it out, but not installed in the car yet...lots of work to be done to the car. It is set up to be a street/strip engine. The motor plate somewhat takes away from the "street" feeling but the goal is to make the wedge to hemi/or backward transition as simple and budget friendly as possible (there is also a future chance of a big CI Wedge). Conversion mounts weren't available at all last year and I wasn't convinced they would be a good choice for my type of abuse.
Don't have any numbers, I've spent the dyno budget on sheetmetal for the car... will probably just do chassis dyno later.
Rich H.
Esse Quam Videri
[Re: Mally69]
#3003847
01/10/22 03:37 PM
01/10/22 03:37 PM
ZIPPY
S.E. Michigan
I really dont know. I just want to build a hemi. I have 5 cars yet to restore after this 69 bee is done. There are so many options as far as which blocks to buy, which heads are better suited for the application there in. Between the indy and stage v lineup idk which route i wanna go yet. Fitting under the factory hood on the 68 charger will be mandatory unless i put it in the 68 Coronet RT i would use SIXPACK hood on that one. I only have 68 69 70 B bodys. Just has to run on pump gas is the only other mandatory object.
Many decisions to be made, and I wish you luck. It might be better to decide what you -don't- want, and you've started that along the lines of fuel type and what hood to use on what car. Once that list is more complete, a picture can be painted.... I changed my mind more than once and struggled a little bit with a few details.... I found the builds I was interested in most of all, folks would usually not talk about them enough to be of much help. The few that did talk about their details ended up being super helpful, even if their combinations and goals were totally different, and by doing that they became influential in the build. Certain universal truths apply, but there are a few Hemi specific things that can be concerning if you never encountered them before. Feel free to give me a shout for directional info...if I don't know the answer I may know someone else who can help.
Rich H.
Esse Quam Videri
