1975 engine into 1979 truck....motor mounts? #3003308
01/08/22 10:54 PM
01/08/22 10:54 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
So we got the torque converter thing situated....now have another question...probably a pretty dumb one at that. I am putting a 1975 360 in a 1979 Truck. Do I use the 1975 rubber mounts, or the 1979 mounts. Looks like they changed in 1979...and thinking thats why my engine and trans are not lining up correctly. I put the 1975 version on...thinking I need the 1979's, as they are a little different. ???
Dave in Colorado
Re: 1975 engine into 1979 truck....motor mounts? [Re: dssaa] #3003310
01/08/22 10:58 PM
01/08/22 10:58 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Same. Used 77 360 when I stuck it into my 84.
Re: 1975 engine into 1979 truck....motor mounts? [Re: NITROUSN] #3003313
01/08/22 11:08 PM
01/08/22 11:08 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
did you leave the 77 mounts on, or use the 84 mounts?
Re: 1975 engine into 1979 truck....motor mounts? [Re: dssaa] #3003323
01/08/22 11:44 PM
01/08/22 11:44 PM
Cab_Burge Online work
Cab_Burge  Online Work
I would use the mounts for that year truck, not the earlier truck scope
Re: 1975 engine into 1979 truck....motor mounts? [Re: Cab_Burge] #3003335
01/09/22 12:31 AM
01/09/22 12:31 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
I just ordered them....18 bucks for the set, guess I should replace them anyways since I have it out....
Re: 1975 engine into 1979 truck....motor mounts? [Re: dssaa] #3003352
01/09/22 03:43 AM
01/09/22 03:43 AM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
2wd or 4wd? shruggy
Re: 1975 engine into 1979 truck....motor mounts? [Re: Hugh Jorgan] #3003384
01/09/22 10:31 AM
01/09/22 10:31 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Big question, car or truck mounts on the 75 engine? Use the truck mounts, big difference
Re: 1975 engine into 1979 truck....motor mounts? [Re: Hugh Jorgan] #3003400
01/09/22 11:30 AM
01/09/22 11:30 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
4wd..
Re: 1975 engine into 1979 truck....motor mounts? [Re: cudaman1969] #3003401
01/09/22 11:30 AM
01/09/22 11:30 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
The donor motor came from a 1975 W200...its going into a 1979 PowerWagon...
Re: 1975 engine into 1979 truck....motor mounts? [Re: dssaa] #3003408
01/09/22 11:58 AM
01/09/22 11:58 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I had a 77 360 from a 4x4 ramcharger that I rebuilt. The 84 was a 6 cylinder 4x4 originally. I used everything from the 77 and dropped it right in.
