Carter mechanical fuel pump #300321
04/26/09 06:43 PM
04/26/09 06:43 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Is there a rebuild kit for the carter mechanical fuel pumps? I my pump is starting to leak around the housing gaskets.
Re: Carter mechanical fuel pump [Re: RROD] #300322
04/26/09 06:53 PM
04/26/09 06:53 PM
I believe there is(not sure where though) but you could probably cut a new gasket much cheaper than a rebuild kit assuming you can find the right material to begin with(fuel resistant neoprene).
