Re: why do keys have to be so ridiculously expensive?
[Re: 3hundred]
#3003001
01/07/22 08:19 PM
01/07/22 08:19 PM
Posts: 2,250 ILLINOIS
volaredon
ILLINOIS
[align:center][/align] Thanks and that's exactly where I wound up getting my 2 new fobs from. I saw some as "cheap" as $17.95 but somehow something told me not to trust them. Even the $60ish each from north coast was more than they should be. Why couldn't they have stayed with the keys such e what's in my 78 fury or my 85 pick up?
[Re: Wagonmaster]
#3003069
01/08/22 01:13 AM
01/08/22 01:13 AM
Superfreak
Superfreak
I have a 2008 mini cooper for driving to work and is now needing a new key fob and up here they want $400 after taxes. These fobs do not have a re-chargeable battery so the auto maker and dealers have you by the balls.
[Re: IMGTX]
#3003154
01/08/22 01:22 PM
01/08/22 01:22 PM
Posts: 2,483 Minneapolis, MN
hemi70se
Minneapolis, MN
In my line of work as someone who buys and repairs Ram trucks I buy from insurance auctions I have to deal with keys quite a bit. First I will say is don't waste your $ on cheap China imitation key, they won't last. The cheapest way for you to get a key is to buy an OEM used one, which should be cheap since it is programmed to a car that is long gone, then send it to Freshcarkeys.com and they will erase the memory of it for $17 and then you can have a dealer or locksmith reprogram it for you. FYI, all the dealerships will tell you that used keys can NEVER be reprogrammed, but they are wrong, I do it with Ram keys all the time.
[Re: hemi70se]
#3003209
01/08/22 03:59 PM
01/08/22 03:59 PM
Posts: 4,153 Canada -- Posts: 4034 -Registe...
5thAve
In my line of work as someone who buys and repairs Ram trucks I buy from insurance auctions I have to deal with keys quite a bit. First I will say is don't waste your $ on cheap China imitation key, they won't last. The cheapest way for you to get a key is to buy an OEM used one, which should be cheap since it is programmed to a car that is long gone, then send it to Freshcarkeys.com and they will erase the memory of it for $17 and then you can have a dealer or locksmith reprogram it for you. FYI, all the dealerships will tell you that used keys can NEVER be reprogrammed, but they are wrong, I do it with Ram keys all the time. That's good to know. I figured you could reprogram old fobs somewhere.
[Re: hemi70se]
#3003429
01/09/22 12:54 PM
01/09/22 12:54 PM
Posts: 3,519 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
In my line of work as someone who buys and repairs Ram trucks I buy from insurance auctions I have to deal with keys quite a bit. First I will say is don't waste your $ on cheap China imitation key, they won't last. The cheapest way for you to get a key is to buy an OEM used one, which should be cheap since it is programmed to a car that is long gone, then send it to Freshcarkeys.com and they will erase the memory of it for $17 and then you can have a dealer or locksmith reprogram it for you. FYI, all the dealerships will tell you that used keys can NEVER be reprogrammed, but they are wrong, I do it with Ram keys all the time. Very interesting! I hope I don't ever need to find out but what is a good source for the used keys? Thanks!
[Re: 340Cuda]
#3003724
01/10/22 09:48 AM
01/10/22 09:48 AM
hemi70se
Minneapolis, MN
In my line of work as someone who buys and repairs Ram trucks I buy from insurance auctions I have to deal with keys quite a bit. First I will say is don't waste your $ on cheap China imitation key, they won't last. The cheapest way for you to get a key is to buy an OEM used one, which should be cheap since it is programmed to a car that is long gone, then send it to Freshcarkeys.com and they will erase the memory of it for $17 and then you can have a dealer or locksmith reprogram it for you. FYI, all the dealerships will tell you that used keys can NEVER be reprogrammed, but they are wrong, I do it with Ram keys all the time. Very interesting! I hope I don't ever need to find out but what is a good source for the used keys? Thanks! I don't have a source for used keys other than myself as I do part out quite a few late model Ram trucks. If I get a builder in that has a bonus 2nd key I'll keep it and have it erased. I would sure think salvage yards would have piles of old keys to cars and trucks they junk and I would think they would be a good source or try Ebay for an old key that someone will sell for $20
