Lsm valve spring removal tool? #3002772
01/07/22 12:08 AM
01/07/22 12:08 AM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline OP
does anyone know the part number to buy for 440-1 heads with t&d shaft mounted rockers?
Re: Lsm valve spring removal tool? [Re: 64hemi330sedan] #3002776
01/07/22 12:43 AM
01/07/22 12:43 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
LSM has an email address and a phone number. Just look up both' then write or call and ask.
Re: Lsm valve spring removal tool? [Re: Dduster] #3002791
01/07/22 04:00 AM
01/07/22 04:00 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Should be their SC-100 for your heads/rockers. I know it works for -1’s/Jesel rockers. But call to confirm. Summit Racing sells their product at a better price IIRC. https://lsmproducts.com/collections/valve-spring-compressors/products/sc-100
"Any fool can know. The point is to understand"
- A. Einstein
Re: Lsm valve spring removal tool? [Re: 64hemi330sedan] #3002813
01/07/22 09:31 AM
01/07/22 09:31 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Looking at the pic posted the price is cheap enough if you have to use that style. Don't know if they make a pedistal one though. I use the old "jesel" steel arm with 'cam' ears to load the retainer. (I've made a aluminum protective 'cap' to avoid marring the retainer FWIW) I just made a new shaft out of the shank of a long (grade8) .750" bolt with 3 holes which catch a pedistal either side of the cylinder in need. This old-style usually works on the car but there may be a combo out there that the compression bar crashes into a fender of master cyl. HTH Are you Brett Wheeler?
Re: Lsm valve spring removal tool? [Re: 64hemi330sedan] #3002854
01/07/22 12:54 PM
01/07/22 12:54 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
According to their website, it's going to be an SC-100. The mounting pedestal and valves are in the stock location.
Joe
Without Data, you’re just another guy with an opinion.
Re: Lsm valve spring removal tool? [Re: sr4440] #3002868
01/07/22 01:25 PM
01/07/22 01:25 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Like said SC-100
Re: Lsm valve spring removal tool? [Re: 64hemi330sedan] #3002976
01/07/22 07:11 PM
01/07/22 07:11 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I just spoke with them. They told me the SC-320 for BBM head spring removal and the PS-100SLC spring pressure tool with the angled handle. I think you get both handles. They also offer the speed tool for the Spring removal tool P#SH-60.
Re: Lsm valve spring removal tool? [Re: mopar dave] #3002977
01/07/22 07:19 PM
01/07/22 07:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I didnt look at that pic very well. SC-320 IS for common shaft stuff -1. stock stuff
Re: Lsm valve spring removal tool? [Re: Al_Alguire] #3002997
01/07/22 08:03 PM
01/07/22 08:03 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I told her it was for BBM with Edelbrock victor max wedge port head. The 320 was the number she suggested. I believe my head and the 440-1 take the same rocker system.
Re: Lsm valve spring removal tool? [Re: 64hemi330sedan] #3003043
01/07/22 10:10 PM
01/07/22 10:10 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
This guy will save you a few dollars on the LSM tools. https://www.gaugesandgadgets.com/
Re: Lsm valve spring removal tool? [Re: 64hemi330sedan] #3003085
01/08/22 07:27 AM
01/08/22 07:27 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
It looks like you could use the 320 with the standard shaft deal you have. I don't know where you are in Ohio but you could borrow my 320 to see if it's what you need.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Lsm valve spring removal tool? [Re: fourgearsavoy] #3003097
01/08/22 09:38 AM
01/08/22 09:38 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Thanks for the offer. I'm in michigan north of flint. The way i read the desciption, looks like the sc-100 works with 440-1 with jesel rockers.
Re: Lsm valve spring removal tool? [Re: 64hemi330sedan] #3003184
01/08/22 02:49 PM
01/08/22 02:49 PM
thanks everyone. i figured it out.
Re: Lsm valve spring removal tool? [Re: 64hemi330sedan] #3003232
01/08/22 05:59 PM
01/08/22 05:59 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Cool, which LSM tool is the correct one for you?
