What RPM would you shift? #3002637
01/06/22 04:21 PM
01/06/22 04:21 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I got some numbers for my new toy and was trying to figure out how to best get it down the track.
5200 lbs with driver.
5 speed auto.
1st: 3.587
2nd: 2.186
3rd: 1.405
4th: 1.0
5th: 0.831
26" rear tire.
2.65 rear gear.
Would you ride the HP plateau or reach farther back and grab a bucket load of that torque?
Unfortunately, it'll be a little while before I can try it out at the track.
- Stu Harmon
Re: What RPM would you shift? [Re: feets] #3002640
01/06/22 04:26 PM
01/06/22 04:26 PM
Washington
madscientist Offline
Washington
If you want to go fast run the RPM up.
Re: What RPM would you shift? [Re: madscientist] #3002642
01/06/22 04:41 PM
01/06/22 04:41 PM
an8sec70cuda Offline
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What RPM would you shift? [Re: feets] #3002649
01/06/22 05:12 PM
01/06/22 05:12 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
lots of TQ, is that with the EFI intake you showed me , same heads ? very good, that should move that heavy car
Re: What RPM would you shift? [Re: CSK] #3002653
01/06/22 05:23 PM
01/06/22 05:23 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
Really nice numbers for “at the wheels” up
Re: What RPM would you shift? [Re: fast68plymouth] #3002676
01/06/22 06:22 PM
01/06/22 06:22 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Seems to me you'd want to launch at around 3k and shift at whatever rpm to be at 3k at the bottom of each shift. Then run it out at the top end.
Re: What RPM would you shift? [Re: an8sec70cuda] #3002680
01/06/22 06:28 PM
01/06/22 06:28 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Originally Posted by an8sec70cuda
5200-5300
iagree
Re: What RPM would you shift? [Re: feets] #3002681
01/06/22 06:28 PM
01/06/22 06:28 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That must be the latest supercar (Mercedes, wasn't it?)
Rich H.
Esse Quam Videri
Re: What RPM would you shift? [Re: ZIPPY] #3002706
01/06/22 08:24 PM
01/06/22 08:24 PM
A727Tflite Offline
A727Tflite  Offline
Run a shift loop at the track when you get there.
Start 500 below max power, and increase you shift points by 2 or 3 hundred until the car falls off for ET and MPH.
Then change your stall speeds on the line the same way until you get your best 60’.
Re: What RPM would you shift? [Re: feets] #3002707
01/06/22 08:25 PM
01/06/22 08:25 PM
Take it to a 1/4-mile track and test shifting it at 4500, 5000, 5500 and 6000 RPM, then look at all the incremental numbers and decide what RPM worked the best scope
If it went fastest shifting at 6000 RPM try 6300, and then 6600 RPM, you need to find out what the car likes for the best results wrench up
Re: What RPM would you shift? [Re: Cab_Burge] #3002715
01/06/22 09:02 PM
01/06/22 09:02 PM
IL
furious70 Offline
furious70  Offline
IL
9 GRAND AND DON'T LOOK BACK whistling
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: What RPM would you shift? [Re: feets] #3002733
01/06/22 09:50 PM
01/06/22 09:50 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
5800-6000
Try this-
https://glennmessersmith.com/shiftpt.html#data
Re: What RPM would you shift? [Re: furious70] #3002734
01/06/22 09:50 PM
01/06/22 09:50 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
AMEN BROTHER!
This is my Mercedes CL65. Bone stock. I'm changing the turbo bypass valves this weekend. That will allow us to tune the V12. The boost will be a bit higher and hold on longer. Most tunes add 100-110 torque and 60-70 hp.
The torque will be hard to hold since it already lights the tires at 50 mph. However, it's the torque that makes the car so nice. 60-130 mph locked in 4th gear took 10.2 seconds. The best it has turned using second and third gears was 6.9 seconds. Not too shabby for an old pig boat.
As for my 541 build, it's waiting on me to wire and plumb the EFI.
- Stu Harmon
Re: What RPM would you shift? [Re: feets] #3002795
01/07/22 06:54 AM
01/07/22 06:54 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Most times at the track you ‘take it too the max’...
You can feel the ‘drop-off’ if you go past peak power... drive
Never found that ‘short shifting’ ever worked for me?
Saves the engine but kills the ET, (phone home) lol... fan
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: What RPM would you shift? [Re: feets] #3003035
01/07/22 09:55 PM
01/07/22 09:55 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Feets, leave it in drive... I had a E55 with a "level 1 tune" and went 11.80 with a "spinning 60ft". I have never heard, though I am sure it happens, where a driver controls the shifts on these cars and runs better than if they left it in drive. Just my .02. And for fun, with a tune, I estimate it to run in the mid 11's if you are on a decent tire.
Re: What RPM would you shift? [Re: feets] #3003238
01/08/22 06:21 PM
01/08/22 06:21 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
In theory, maximizing the hp under the hp curve should yeild the best et and mph. This theory works well with my cars, but I have a stock torque converter. I think this theory breaks down with higher stall race converters when the motor is back into the converter at the shift recovery rpm. The cam LSA and ICL probably play a part as well, and mine are not conventional..
Your shift/shift recovery rpm ratios are 0.61, 0.64, and 0.71 for 1-2, 2-3, 3-4 gear changes respectively.
With that, assuming you have a tight converter, I'm in the 5700-5800 camp at least for 1-2, and maybe 2-3. The 3-4 shift.might be 5400-5500. That's just eye-balling the graph and pushing the shift recovery hp up close to the shift hp.
This has played out pretty well on both motors I had in my charger with a torqeflite (0.59 and 0.69) . My 508 peak power was about 5600, but after a bunch of track testing, I shift 1-2 at 6500, and 2-3 at 6200.
Re: What RPM would you shift? [Re: TheOtherDodge] #3003434
01/09/22 01:08 PM
01/09/22 01:08 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I took it out for the last run of the 2021 Texas Muscle Car Club Challenge. It was an 1/8 mile whice is NOT where this thing belongs.
I was surprised the Michelin PS4S hooked as well as they did. It had to be in the track prep.
I left it in auto with sport on and ESP off. About 300 feet out it hazed he tires for a couple seconds. Naturally, it starts to feel good at the shift into third at 80 mph and speed builds rapidly but the 1/8 comes up quickly.
I was lined up next to a Challenger 1320 on stickies. He sent me home by a tenth and a half but I felt good about having 2 mph on him.
This thing is an awesome highway cruiser but it's short game is week.
- Stu Harmon
Re: What RPM would you shift? [Re: feets] #3003491
01/09/22 04:01 PM
01/09/22 04:01 PM
moparx Offline
moparx  Offline
boy, a tenth and a half ain't very much in the grand scheme of things.
you should be able to easily figure that out with not much practice.
pretty good outing i would say. up
beer
