1970 Cuda brake questions
#3001166
01/02/22 03:47 PM
01/02/22 03:47 PM
Posts: 1,419 STL
cdstl
STL
Ok, here goes.
Disc brake car. I understand that there is a Distribution block and a rear hold off block. I also see that Inline tube sells a 3 port hold off block.
A disc brake car needs the Distribution block, obviously, and I would imagine the rear hold off block. Does the rear hold off block limit the brake pressure to the rear brakes? Do you combine the 3 port hold off block in there anywhere?
I have an FSM and I've looked at the pictures and text but I obviously still have questions.
Disc Brake Distribution Block
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 2001 Ram 5.2 4x4 auto, 1996 Ram 5.9 2x4 auto, 1965 Satellite 4 speed
Re: 1970 Cuda brake questions
[Re: cdstl]
#3001199
01/02/22 04:43 PM
01/02/22 04:43 PM
Posts: 1,419 STL
cdstl
STL
Thanks for the input guys, that was in record time. It's Sunday I guess.
It's a disc/drum car.
So it sounds like I can delete the metering valve and just use the distribution block and proportioning valve. Cass, do you have a recommendation for a combination distribution/proportioning valve?
Thanks again.
[Re: cdstl]
#3001202
01/02/22 04:56 PM
01/02/22 04:56 PM
Posts: 3,889 nowhere
Sniper
nowhere
I would not do that. It is also designed to prevent front brake lock up under light braking and slippery conditions. Sand, gravel, rain, ice, snow, oil, etc. Though the book specifically says icy any of those conditions can apply.
[Re: cdstl]
#3001203
01/02/22 04:58 PM
01/02/22 04:58 PM
Posts: 1,419 STL
cdstl
STL
I actually found this from a place called Carolina Classic trucks. They offer it as a replacement for the '73 Prop valve which is not reproduced. https://www.carolinaclassictrucks.com/73-cuda-prop-valve.html
[Re: cdstl]
#3001245
01/02/22 06:20 PM
01/02/22 06:20 PM
Posts: 586 California
BigDaddy440
California
Side note: I learned last year when using a prop valve with a safety mechanism (as pictured above), it's important to remove the brake warning light "switch" and replace it with special thread-in tool that holds the valve in place so that while bleeding the brakes the safety mechanism doesn't trigger when it "senses" a lack of pressure during bleeding. These safety mechanisms are nearly impossible to reset without taking the prop valve apart. Do your research to reduce frustration.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
