Piston above deck??? and other build options
#3001358
01/03/22 02:14 AM
01/03/22 02:14 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Future build option brainstorming: current combo is a .040 over 400 - 451. Turned factory crank, 6.76 rods & Icon 1.322 ht pistons. CNC’d stealth heads.
Looking at the future with my 400 block, and a 512 kit would be my preference, but my block has been decked slightly and mainline honed, so I believe the deck ht to be 9.960. The 440 source kit puts the piston right at 9.98. So what are the issues with running .020 above deck? Obviously head gasket choice becomes paramount, clear of the bore and thick enough to keep the pistons off the head. What issues are there beside that?
2nd option is the 500 kit, this combo would keep the piston within the hole, but I want longevity, and I’m not crazy about the short piston ht and oil ring support rails in this combo. Weigh in on those issues if you have input.
Lastly, I could get a set of 6.700 BBC rods, use my existing slugs and turn my crank to 3.875 and land at zero deck for approx. 470 cubes. This would perhaps save me a little money that I could put elsewhere, but probably not much. Also, both of the source kits are available @ .042 over, so I could hone to those pistons from where I’m at now. Current bore is in good shape, but I can’t help but think if you’re going to rebuild, you might as well have new slugs and such.
Goal is approx. 650 hp, or whatever I need to put my B-body into the low-mid 10’s. Thanks for your thoughts.
Re: Piston above deck??? and other build options
[Re: earlymopar]
#3001386
01/03/22 09:37 AM
01/03/22 09:37 AM
Posts: 9,835 MI, usa
dvw
MI, usa
If you use the proper thickness head, gasket the piston to head remains correct. As does the piston to valve. If it’s .020” out of the block, run a .060” gasket. No machining necessary. A .060” gasket will be pricey. You’ll need Cometics or something similar. If you chose to run a open chamber head the entire chamber has to be equal or greater to the bore size. And in this case piston to valve would be closer. In most cases quench depth would still be to great to be of any help. Doug
[Re: dvw]
#3001440
01/03/22 12:28 PM
01/03/22 12:28 PM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My choice would be a 4.25 stroke, 6.535 rod, piston set up for Max compression you are willing to run. Cubes and compression are very effective in upping the hp potential of your build . .043 top and second rings, gas ports, don't worry about rod length or piston pins height being her n the rings. Check to see if it is possible to cut the closed side of the piston only. That will create a bit more compression and cost about as much as a thick cometic gasket, or less. Watch out for valve to piston clearance, or the need to add some. If you are going to spend money to build a good motor, why not build it to make an extra 75 to 100 hp by employing all the changes you can that add power? A b body isn't light. Build the 512. Use narrow rings. They work, and live. What heads do you plan to use?
[Re: gregsdart]
#3001449
01/03/22 01:00 PM
01/03/22 01:00 PM
Posts: 1,030 ohio
67mprfan
ohio
Have you tried the M1 intake yet or consider a bigger cam. Just tossing ideas around to take advantage of the combo you have currently
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#3001545
01/03/22 03:41 PM
01/03/22 03:41 PM
gregsdart
In addition, check out Line2Line coatings. If you rebuild in the future, you can coat the piston skirts to build them back up to desired size. I had a 550 cube bigblock set of pistons done to take up . 0043 that the bores grew from rehones, scratch cleanup. This was a high end build, made 926 hp. L2L says the coating is applied about . 0025 thicker than needed, and wears in during a breaking procedure they lay out. They can coat pistons to . 020 oversize! Which means you can reuse your current block many times. The coating cost me $300.
[Re: gregsdart]
#3001652
01/03/22 04:33 PM
01/03/22 04:33 PM
Posts: 2,857 Pattison Texas
CSK
Pattison Texas
My 440 source 400 512 is .016 out of the hole, I run a .052 head gasket, been that way for over 11k miles
[Re: 67mprfan]
#3001833
01/04/22 12:48 AM
01/04/22 12:48 AM
StealthWedge67
Puyallup, WA
Have you tried the M1 intake yet or consider a bigger cam. Just tossing ideas around to take advantage of the combo you have currently I never did get it installed last year. It’ll be on the car in ‘22 though. I was going to do a quick refresh and add more camshaft; I contacted Hughes to talk about cam selection. Their advice was that I didn’t have enough cylinder pressure to take advantage of more camshaft. Static compression currently sits at 10.7:1, but cylinder pressure is only at 155. Does that seem low to you guys? It is pretty even across the board with a low of 150 and a high of 158. This, along with the reality that it is 12 years old now and was originally built as a street / strip effort has me looking at more race-specific build options for the future. The heads will continue to be the CNC Stealths for the purpose of this conversation. Carb is an annular 1000-4150.
[Re: gregsdart]
#3001839
01/04/22 12:58 AM
01/04/22 12:58 AM
StealthWedge67
Puyallup, WA
My choice would be a 4.25 stroke, 6.535 rod, piston set up for Max compression you are willing to run. Cubes and compression are very effective in upping the hp potential of your build . .043 top and second rings, gas ports, don't worry about rod length or piston pins height being her n the rings. Check to see if it is possible to cut the closed side of the piston only. That will create a bit more compression and cost about as much as a thick cometic gasket, or less. Watch out for valve to piston clearance, or the need to add some. If you are going to spend money to build a good motor, why not build it to make an extra 75 to 100 hp by employing all the changes you can that add power? A b body isn't light. Build the 512. Use narrow rings. They work, and live. What heads do you plan to use? I like this line of thinking. As said above, my CNC Stealths will have to do for the purposes of this discussion. But the obvious next step could be a set of real race heads at some point. Regarding compression: I really like being able to run pump gas. I’ve been running non-ethanol 93 from a local street pump. The cost factor of race fuel, especially with the direction the price of gas is going is a reality that is hard to ignore. I think I could go to 11.25 - maybe 11.5:1 with perhaps at least a mixture of mostly pump fuel. ?? I really don’t want to be roped into $14- / gallon fuel just to go bracket racing.
[Re: StealthWedge67]
#3001843
01/04/22 01:17 AM
01/04/22 01:17 AM
StealthWedge67
Puyallup, WA
Since Greg asked about heads, What about option #4: refresh only (rings and bearings); and spend my money on heads instead. Would a good set of Indy SR’s or something similar on a flat-top 451 get me to my goal for a lot less $$? It also would allow me to utiluze my current gearing with less piston speed (??). Just thinking out loud here, I guess.
#3001890
01/04/22 10:22 AM
01/04/22 10:22 AM
Posts: 1,030 ohio
67mprfan
ohio
Since Greg asked about heads, What about option #4: refresh only (rings and bearings); and spend my money on heads instead. Would a good set of Indy SR’s or something similar on a flat-top 451 get me to my goal for a lot less $$? It also would allow me to utiluze my current gearing with less piston speed (??). Just thinking out loud here, I guess. How much would you have to mill the heads to be able to bump the compression up some? Maybe try and borrow a dominator carb along with the intake swap might show some results you are wanting. Good luck on whatever you decide your combo has always been impressive to me
#3002182
01/05/22 12:04 AM
01/05/22 12:04 AM
gregsdart
My choice would be a 4.25 stroke, 6.535 rod, piston set up for Max compression you are willing to run. Cubes and compression are very effective in upping the hp potential of your build . .043 top and second rings, gas ports, don't worry about rod length or piston pins height being her n the rings. Check to see if it is possible to cut the closed side of the piston only. That will create a bit more compression and cost about as much as a thick cometic gasket, or less. Watch out for valve to piston clearance, or the need to add some. If you are going to spend money to build a good motor, why not build it to make an extra 75 to 100 hp by employing all the changes you can that add power? A b body isn't light. Build the 512. Use narrow rings. They work, and live. What heads do you plan to use? I like this line of thinking. As said above, my CNC Stealths will have to do for the purposes of this discussion. But the obvious next step could be a set of real race heads at some point. Regarding compression: I really like being able to run pump gas. I’ve been running non-ethanol 93 from a local street pump. The cost factor of race fuel, especially with the direction the price of gas is going is a reality that is hard to ignore. I think I could go to 11.25 - maybe 11.5:1 with perhaps at least a mixture of mostly pump fuel. ?? I really don’t want to be roped into $14- / gallon fuel just to go bracket racing. How much e85 could a guy add to 93 pure gas comes to mind. If your carb can accept being jetted up 20 percent say, that may be as much as 1/3 e85 to 2/3 93, and would possibly allow a full point or more compression? All this is off the top of my head. You might get away with 40 percent e85. If it interests you as a possible way to go, research thoroughly.
[Re: gregsdart]
#3002260
01/05/22 12:38 PM
01/05/22 12:38 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Heavy car, pump gas compression?
Cubes are your friend.
