Re: NHOU undercoating?
[Re: chrisf]
#3001106
01/02/22 01:28 PM
01/02/22 01:28 PM
Posts: 19,342 north of coder
moparx
a guy in town does oil undercoating, but i don't know what kind he uses. i have been oiling my "bus" [99 caravan] since i acquired it in 2014. it came from arazona, so it had almost zero rust except where the paint was knocked off. i drilled extra holes in the doors and gate, plus drilled holes just above the foam they put in from the factory on the dog legs. also popped the vent holes and other caps on the inside of the rockers, then saturated the foam with oil. pulled the tail lights and blasted the inside quarter panels good as well. just about anywhere the factory used foam was saturated with oil, and any place there was a body plug of sorts got the spray as well. i do this just before the weather turns cold, but that stuff leaks EVERYWHERE when the temperature gets above 60 or so. so far, i think this will keep this thing going until i croak. i also took the spare tire out from underneath and tossed it in the back. i did this for two reasons. 1 : oil the floor pan, plus the spare and the crank mechanism can't collect anything that would cause rust. and 2 : easier for my creaky bonzes to get the spare out of the back than from underneath.
[Re: moparx]
#3001189
01/02/22 04:26 PM
01/02/22 04:26 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
I have used machine oil, cosmoline, and 3m cavity wax , formally known rust fighter, and the 3m applicator kit to get in doors and doglegs since the 80s, it works. I now use krown rustproofing oill inside and cavity wax on the underside, the reason being cavity wax lasts a long time, and can be removed with a hot water pressure washer. I think what you are looking at is about the same as krown, just figure out a way to get it everywhere and wash and reapply once a year and you are good to go. Our new cars always get krown dealer applied krown oil, only $160 to do a van. I think with the salt and beet juice mix they use here, along with car washes recycling water, it is the only thing that works short of not driving the car. It does make a mess for a while but...
[Re: 4406bbl]
#3001196
01/02/22 04:35 PM
01/02/22 04:35 PM
Posts: 8,392 Highland, MI.
Sunroofcuda
Highland, MI.
I had 2 vehicles sprayed with Krown several years ago. The Krown is like spraying vegetable oil & literally rinses off in a few weeks. That was my experience. Fluid Film is the way to go IMO. Smells & looks like the old Texaco rustproofing - the old Texaco was dynamite!
[Re: volaredon]
#3003194
01/08/22 03:04 PM
01/08/22 03:04 PM
moparx
from what i have read about that stuff, it works pretty good, but has a tendency to "wash" off. if doing it yourself, you can keep an eye on it, and apply more if necessary. for sheet metal, i would drill extra holes so you can be absolutely sure all seams and surfaces get covered. and like my bus, removing things like tail lights can give good access to areas not normally covered, but can need protected as much as possible.
