Fan Alternator belt 1970 Hemicuda #2998857
12/27/21 01:44 PM
12/27/21 01:44 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
My reproduction 1970 Hemicuda fan/ alternator belt came loose the other day. Heard rumors that these belts come loose at "higher" RPM. Does anyone recommend a good after market belt to replace these repos? Need part number to order one.
Thanks for your help.
Re: Fan Alternator belt 1970 Hemicuda [Re: sbcjd] #2999127
12/28/21 12:01 PM
12/28/21 12:01 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
I have Quanta numbered belts on my 1970 Hemicuda 4 speed convertible and I have never thrown a belt. I also have power steering and the belt to it has never been thrown. But my pulleys are all original and perfectly lined up.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Fan Alternator belt 1970 Hemicuda [Re: MOPARMIKE69] #2999152
12/28/21 01:21 PM
12/28/21 01:21 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
I have manual steering so I have only the one belt. I also have the Quanta belt that I installed 2 years ago. I have put about 250 miles on the car in the last year but the other day I took the engine up to around 5,000 RPM and then notice the temperature gauge going quite high. I shut down the engine and notice the belt had come off all the pulleys. My engine is all original so I do have the correct pulleys. I do have a spare Quanta belt belt but now I am worried if I drive the car that belt may come off. That is why I am looking for a stock replacement belt like a Gates belt.
Re: Fan Alternator belt 1970 Hemicuda [Re: sbcjd] #2999159
12/28/21 01:32 PM
12/28/21 01:32 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I put a set of the quanta belts on my old 1970 Challenger 340.
Drove it home maybe 35 miles and they were squealing bad.
I tightened them up and within maybe another 100 miles they were squealing again,
I pulled them off dropped them in the trash and bought a set of Mopar brand belts and never looked back.
I need to look at some belts here soon for my current car . Problem is all the current belts have this horrible waffled backside that looks like crap
Re: Fan Alternator belt 1970 Hemicuda [Re: gtx6970] #2999163
12/28/21 01:52 PM
12/28/21 01:52 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
I understand what you are saying. I just worry my belt will come off while I am driving the car and then I would have to get it towed home. They other day when my belt came off I was in my garage just running the engine. So I need a belt that I can rely on. I wished that I had saved my old Mopar belt.
Re: Fan Alternator belt 1970 Hemicuda [Re: gtx6970] #2999165
12/28/21 01:56 PM
12/28/21 01:56 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Does Mopar still make a belt for my application?
Re: Fan Alternator belt 1970 Hemicuda [Re: sbcjd] #2999184
12/28/21 02:44 PM
12/28/21 02:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Carry a spare belt and a 9/16" X 1/2" box wrench.
Re: Fan Alternator belt 1970 Hemicuda [Re: John_Kunkel] #2999276
12/28/21 07:57 PM
12/28/21 07:57 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
John, that would be a great idea if I were 50 or 60 years old. But at 82 I just want to enjoy driving the car for as long as I can and not be concerned about loosing a fan belt and over heating the engine.
Re: Fan Alternator belt 1970 Hemicuda [Re: sbcjd] #2999343
12/28/21 10:50 PM
12/28/21 10:50 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Take the one off.
Take it to your local parts supplier and match it .
I think your best option right now is a dayco belt. Or Autozone shows a smooth face belt in the duralast brand
Install....then drop the quanta belt in the trash and drive on
Re: Fan Alternator belt 1970 Hemicuda [Re: sbcjd] #2999351
12/28/21 11:24 PM
12/28/21 11:24 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
One of the pit falls of owning/driving an older car & having to deal with the crap stuff they sell for them today.
Toss Up: Use NEW questionable parts or OLD notable parts that aren't "aged/weathered".
Re: Fan Alternator belt 1970 Hemicuda [Re: gtx6970] #2999356
12/28/21 11:43 PM
12/28/21 11:43 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Bill,
I think that is the best solution to my problem
Re: Fan Alternator belt 1970 Hemicuda [Re: sbcjd] #2999404
12/29/21 08:51 AM
12/29/21 08:51 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I guess Im a slow learner that got lucky.. I run a single belt also on my roadrunner and a Quanta jumped off at high rpm, I got another and its been good to me knock on wood.
1969 Hemi Roadrunner 2nd owner
Re: Fan Alternator belt 1970 Hemicuda [Re: sbcjd] #2999441
12/29/21 11:22 AM
12/29/21 11:22 AM
central il.
second 70 Offline
second 70  Offline
central il.
I was having the same problem and put on a Dayco top cog 15470 10 years ago and it hasn't come off yet.
Mike
Re: Fan Alternator belt 1970 Hemicuda [Re: sbcjd] #2999517
12/29/21 01:33 PM
12/29/21 01:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'm not far behind you..,..if you can check the oil, you can replace a fan belt. The ammeter is a better indicator of a tossed belt than the temp gauge.
Re: Fan Alternator belt 1970 Hemicuda [Re: John_Kunkel] #2999532
12/29/21 02:21 PM
12/29/21 02:21 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
John,
Would you mind explaining that statement as my ammeter has been showing a discharge with the engine running. Thank you.
Re: Fan Alternator belt 1970 Hemicuda [Re: sbcjd] #2999893
12/30/21 12:59 PM
12/30/21 12:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
At cruise RPM, the ammeter should be centered or a little into the charge side. In normal operation, if a belt is tossed, the ammeter will react immediately where the temp gauge will be slow to show a rise in temp.
Re: Fan Alternator belt 1970 Hemicuda [Re: John_Kunkel] #2999932
12/30/21 01:40 PM
12/30/21 01:40 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
My car has some older Mopar brand belts on it. They dont make a noise at any time cold or hot. But they are getting old and I drive my car to much to worry about it pitching a belt . Especially on some of the drives I take it on when there really is no ideal spot to pull over and wrench on it . Or close to anything parts house wise
And I am thinking its time to look into some replacements, soon
