Mopars with MANUAL disc brakes? #2999325
12/28/21 09:47 PM
12/28/21 09:47 PM
Polson, MT
DoctorDiff Offline OP
Polson, MT
What Mopar cars were originally available with MANUAL disc brakes? I only remember seeing A bodies.
Re: Mopars with MANUAL disc brakes? [Re: DoctorDiff] #2999338
12/28/21 10:40 PM
12/28/21 10:40 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
A bodies were. There was an obscure B body manual disc brake option in 1970 listed for B body taxi cabs.
I have an NOS master cylinder listed as being for 72-74 E bodies with manual disc brakes, which may be for 72-74 B body also.
I’ve never actually seen a 72-74 B or E body with manual disc brakes in person or in a magazine article, but seeing how those years usually get ignored over their 70 and 71 predecessors that doesn’t mean much.
Re: Mopars with MANUAL disc brakes? [Re: DoctorDiff] #2999464
12/29/21 11:55 AM
12/29/21 11:55 AM
NY
twodoorpost Offline
twodoorpost  Offline
NY
I did a manual disc brake swap in 1973 and used all the parts, including the master cylinder which came with the mounting studs installed, from a 1967-1969 B body taxi / police car. I bought everything from Chrysler parts department. Had to be manual brakes as I was using Max Wedge exhaust manifolds.
Re: Mopars with MANUAL disc brakes? [Re: twodoorpost] #2999496
12/29/21 12:58 PM
12/29/21 12:58 PM
moparx Offline
moparx  Offline
my brother had a 73 or 74 sattelite 4 door, 318/904 combo, power steering, but factory manual disc brakes.
i converted it over to power brakes because his wife [at the time] couldn't stop the car.
i hooked the booster to the original pedal, and if you just LOOKED at applying the brakes, it would put you through the windshield ! laugh2
beer
Re: Mopars with MANUAL disc brakes? [Re: moparx] #2999505
12/29/21 01:17 PM
12/29/21 01:17 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Mom & Dad bought 4dr Valiant new in 1976 off the lot. /6, with power steering and light package as only options on it !! . . . Not even a radio - I still have that delete plate ! . . . BUT, it did come with manual disc brakes on front . . . never seemed to be an issue.
On my 70 Sport Satellite, I upgraded from the 4 wheel manual drums, to manual front disc/back drums . . . thanks to Dr. Diff, used the aluminum master cylinder, and a set of his stainless steel braided front hoses to the calipers . . . never felt that it needs power brakes, pedal feel is good and not too hard at all . . .
Re: Mopars with MANUAL disc brakes? [Re: DoctorDiff] #2999568
12/29/21 03:37 PM
12/29/21 03:37 PM
Missouri
randavis Offline
randavis  Offline
Missouri
I ordered a Challenger in Dec, 73 with manual front disks. I still have the car and drive it regularly, still with manual disks. It does take more pedal effort than power, but it seems to stop the car well. I replaced the original master cylinder when I restored the car in 2016, The replacement part doesn't look the same as the original. IIRC, I got it from Advanced Auto.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Mopars with MANUAL disc brakes? [Re: randavis] #2999612
12/29/21 05:58 PM
12/29/21 05:58 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
According to GG only A bodies. In the 45 years of owning well over 150 Mopars I too have never seen a B/E body with manual disc. I would like to see the factory taxi and cop car options.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Mopars with MANUAL disc brakes? [Re: moparmarks] #2999619
12/29/21 06:14 PM
12/29/21 06:14 PM
Crook County, ILL
Crook County, ILL
Ask and ye shall receive…
https://www.ebay.com/itm/373372801964?
Re: Mopars with MANUAL disc brakes? [Re: Mastershake340] #2999627
12/29/21 06:40 PM
12/29/21 06:40 PM
Crook County, ILL
Crook County, ILL
This is the part listed for ‘72-‘74 B & E body manual disc brakes. It looks like the master cylinder for ‘71-‘74 power disc brakes but the casting number is 2229271.
This sample has a Bendix label that says reman but everything about it looks NOS.
Re: Mopars with MANUAL disc brakes? [Re: moparmarks] #2999936
12/30/21 01:43 PM
12/30/21 01:43 PM
moparx Offline
moparx  Offline
well, GG is not correct, as i have seen different ! in my junkyard days, we took in a 72 or 73 318 charger with manual discs, and a 71 /6 challenger with manual discs that i can remember off the top of my foggy head. odd combos for sure. then there was the car my brother had. it was changed over to power using my junkyard parts.
i'm sure there were others out there across the country, no matter what galen says.
beer
Re: Mopars with MANUAL disc brakes? [Re: moparx] #2999955
12/30/21 02:10 PM
12/30/21 02:10 PM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
Back in the early 80's the 73 RR I had was manual disc, 340,4sp car.
Re: Mopars with MANUAL disc brakes? [Re: Ramtough] #3000142
12/30/21 10:16 PM
12/30/21 10:16 PM
moparmarks Offline
moparmarks  Offline
Sure it's not the first time.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Mopars with MANUAL disc brakes? [Re: moparmarks] #3000199
12/31/21 01:52 AM
12/31/21 01:52 AM
Cab_Burge Online work
Cab_Burge  Online Work
whistling grin
Re: Mopars with MANUAL disc brakes? [Re: Ramtough] #3000251
12/31/21 11:50 AM
12/31/21 11:50 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Back in '84 I had a '73 Satellite Sebring with manual disc. Car had a 318/904. I used to have just a general overall pic of the engine that showed the MC, but I've long since lost it.
John
Re: Mopars with MANUAL disc brakes? [Re: DoctorDiff] #3000292
12/31/21 01:43 PM
12/31/21 01:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Mopars with MANUAL disc brakes? [Re: SattyNoCar] #3000318
12/31/21 02:55 PM
12/31/21 02:55 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Back in the day I had a 72 Barracuda with manual discs......318/auto in dreaded triple green
Re: Mopars with MANUAL disc brakes? [Re: moparx] #3000403
12/31/21 06:19 PM
12/31/21 06:19 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I have an 80 2 door Volare that came that way from the factory. I also have a spare NOS master for it in case I ever need to replace the 41 year old original.
Theres a guy on the /6 forum recently with an ~82 D150 that he claims is so equipped, was asking about adding power brakes to it
Re: Mopars with MANUAL disc brakes? [Re: volaredon] #3000560
01/01/22 09:39 AM
01/01/22 09:39 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
My '73 Challenger has manual front disc brakes, although it's been upgraded since I purchased it to use larger rotors than it came with.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Mopars with MANUAL disc brakes? [Re: Brad_Haak] #3000589
01/01/22 12:10 PM
01/01/22 12:10 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Had a 70 Duster race car that way, best stopping car I ever had and it had the drum brake master on it too. Original /6 auto, I put a 383 in it.
Re: Mopars with MANUAL disc brakes? [Re: moparmarks] #3000592
01/01/22 12:19 PM
01/01/22 12:19 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Agree, but you can’t tell him so either
