Re: Pro shifted or Face plated 833 on a road course
[Re: joes68340s]
#2999082
12/28/21 04:07 AM
12/28/21 04:07 AM
Posts: 268 Anchorage, Alaska
metallicareload
Anchorage, Alaska
I've never driven either, but I would think coming in and out of corners on/off the throttle would be hard on either. With proshifting is every other tooth ground off in the slider also? If not, it might have an advantage. If yes, I think faceplated is better 11/10 times
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: metallicareload]
#2999129
12/28/21 12:02 PM
12/28/21 12:02 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
The road race sliders in my G Force GF5R have similar spacing between the dogs (teeth on the slider) as the Liberty's Gears face plated a-833 in my GTS. Aside from noise you should not have any issue. I would think the face plated box would be the only one that could survive from an an endurance standpoint, especially with downshifting. Are you having trouble racing with a syncro'd box? If it was my car and the rules allowed it I'd move into a G-Force 101a. Much stouter platform and you can choose your ratios. The one piece cluster gear in the a833 makes it a bit less robust for racing as well.
[Re: Jeremiah]
#2999261
12/28/21 07:16 PM
12/28/21 07:16 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
What car do you have a G Force GF5R trans in ?
#2999513
12/29/21 01:28 PM
12/29/21 01:28 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've never driven either, but I would think coming in and out of corners on/off the throttle would be hard on either. Practice up on heel/toe shifting.
