Re: How to remove big block from a Dodge Sportsman motor home [Re: 1969ronnie] #2999262
12/28/21 07:19 PM
12/28/21 07:19 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Re: How to remove big block from a Dodge Sportsman motor home [Re: R/T1968R/T] #2999349
12/28/21 11:15 PM
12/28/21 11:15 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i took a 440 and trans out of a class a motorhome,it went out the front after some removal of grill,core support etc
my ladder of success is missing some rungs
Re: How to remove big block from a Dodge Sportsman motor home [Re: rhad] #2999352
12/28/21 11:35 PM
12/28/21 11:35 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Right. However the poster said sportsman chassis which should be a B series van conversion and class C.
Re: How to remove big block from a Dodge Sportsman motor home [Re: 340727dart] #2999632
12/29/21 06:57 PM
12/29/21 06:57 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
Factory recommends out the front on any of the B series models like that, get a short chain, remove the intake, keep it tight and you can slip it right out the front.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: How to remove big block from a Dodge Sportsman motor home [Re: MonGoo$e] #2999699
12/29/21 09:22 PM
12/29/21 09:22 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
"Slip it right out the front" may be the factory terms, but "slip" probably isn't the correct verb. With the grill and everything removed it will come out the front. The clearances can be really tight. I can see where a few could have slipped right out, but I suspect most were more challenging. One of the two I did was easier then the other. Loosing the exhaust manifolds, the intake manifold, and the motor & trans mounts on the motor/trans sure helps with the clearances. You also want to be sure you can back the engine picker straight back 8'-10'. Have a helper with a big prybar. Gene
Re: How to remove big block from a Dodge Sportsman motor home [Re: poorboy] #2999964
12/30/21 02:31 PM
12/30/21 02:31 PM
moparx Offline
moparx  Offline
or just have the "roadkill" guys over. they will have it out in no time, and film it for posterior's sake.............. biggrin
beer
Re: How to remove big block from a Dodge Sportsman - update [Re: 340727dart] #3006012
01/16/22 07:40 PM
01/16/22 07:40 PM
Arkansas
340727dart Offline OP
Arkansas
I looked at the motorhome a couple of days ago. It is definitely a 440.
A buddy of mine is keeping me motivated to start working on it.
The tires are all still holding air but they are all sunk to the rims in dirt.
What am I going to do with the drive train? I have no freakin' idea. My friend has told me I can have the whole thing. She just wants it gone.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: How to remove big block from a Dodge Sportsman - update [Re: 340727dart] #3006025
01/16/22 08:35 PM
01/16/22 08:35 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
before you take on this albatross make sure you can scrap the rest, lots of places want nothing to do with RV remains.
Re: How to remove big block from a Dodge Sportsman - update [Re: 340727dart] #3006031
01/16/22 08:42 PM
01/16/22 08:42 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Are you allowed to burn stuff where it is located? laugh2
Re: How to remove big block from a Dodge Sportsman motor home [Re: R/T1968R/T] #3006053
01/16/22 09:24 PM
01/16/22 09:24 PM
Originally Posted by R/T1968R/T
Those guys are typical educated idiots down
More interested in film time than safety and time savings methods puke down twocents
Re: How to remove big block from a Dodge Sportsman - update [Re: Hugh Jorgan] #3006180
01/17/22 12:45 PM
01/17/22 12:45 PM
Arkansas
Arkansas
No worries. The motorhome is located on my friend's 65 acres. There's not much we can't do and haven't done there.
