Torsion Bar Adjuster / Bump Stop #2997894
12/23/21 02:46 PM
12/23/21 02:46 PM
Tampa Bay
BadFishy Offline OP
BadFishy  Offline OP
Tampa Bay
Hi, I’ve been trying to figure out why the driver side adjuster bolt is about an inch lower than the passenger side, and driver side wedge bump stop is right against the subframe? The passenger side wedge bump stop is 1/4” to the subframe.
Level floor. Original torsion bars. Adjuster bolts not stripped. 440, aluminum heads, intake manifold, water pump, battery relocated to trunk passenger side, headers.
Front end is 25” high at both front wheel openings. Rear passenger wheel openings are 25 1/2” high driver, 25” high passenger.
I had a PST front end kit installed a couple hundred miles ago, new front sway bar, tubular upper arms, and aligned, so many parts are new - but the adjuster and bump stop issue was the same before then.
See pics. I would appreciate any help and insight!
1971 Cuda, 440 custom-build
Re: Torsion Bar Adjuster / Bump Stop [Re: BadFishy] #2997942
12/23/21 05:01 PM
12/23/21 05:01 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Tired bar on one side. Also ride height is checked at the control arms.
Angry white pureblood male
Re: Torsion Bar Adjuster / Bump Stop [Re: ruderunner] #2997968
12/23/21 06:06 PM
12/23/21 06:06 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
It may be possible one torsion bar was not indexed into the LCA hex like the other.
25” to top of wheel lip is sorta low. What is you front tire size? The higher the wheel diameter, it raises the wheel ball joint.
So as you increase the diameter of the tire AND keep the chassis at the same height, the gap between the LCA bumper to frame get smaller.
Re: Torsion Bar Adjuster / Bump Stop [Re: autoxcuda] #2997990
12/23/21 07:21 PM
12/23/21 07:21 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I would tend to agree with that ^^^.
It's a hex shape, but I don't know how the thread count would equate to the difference in clocking.
I'll assume it's got stock bars, not drag-racing or 6-cyl bars.
I've run into a deal before where the drag bars got old/weak and one side bolt was cranked to the max to keep it off the LCA bump stop.
Re: Torsion Bar Adjuster / Bump Stop [Re: topside] #2998013
12/23/21 09:12 PM
12/23/21 09:12 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I've been under a lot of torsion bar equipped Mopars, very few adjusting bolts have had the same number of threads showing between the bolt head and the adjustment anchor on both sides of the car. The purpose of the adjustment is to correct a minor incorrect level of the front of the car, measured at the bottom of the lower control arms at the lowest point on the control arms on a level surface. The threads on the adjusting bolt, and the height of the wheel opening are really poor points at which to check how level the lower control arms are, way too many variables involved.
Concern over a 1/4" height difference between the wheel opening on one side compared to the other side assumes the ground on which the car is sitting is perfectly level, the tape measure is perfectly straight vertical, and the both fenders are correctly positioned on the car. It is not unusual for the driver side to be adjusted slightly higher then the passenger side at astatic level to compensate for not having a driver sitting in the seat, the theory is, once the driver is in the seat, the car will sit level. Mopars of the performance era were designed with a panel tolerance of + or - a 1/4". Your measured difference is well within the factory tolerance.
Personally, I'd go with the ground wasn't level, or the tape measure wasn't straight, and no one is going to crawl under your car and count the number of threads on the torsion bar adjusting bolt sticking below your control arms. Then I'd move on to more important things. Gene
Re: Torsion Bar Adjuster / Bump Stop [Re: BadFishy] #2998014
12/23/21 09:15 PM
12/23/21 09:15 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
do you have a pair of bar one right and one left , they are different !
Re: Torsion Bar Adjuster / Bump Stop [Re: calrobb2000] #2998049
12/23/21 10:07 PM
12/23/21 10:07 PM
So Cal
FY1 AAR Offline
FY1 AAR  Offline
So Cal
I am with autoxcuda was not indexed right
Re: Torsion Bar Adjuster / Bump Stop [Re: FY1 AAR] #2998084
12/23/21 10:58 PM
12/23/21 10:58 PM
Tampa Bay
BadFishy Offline OP
BadFishy  Offline OP
Tampa Bay
First, thanks everyone for the help.
I’ve got the front intentionally at 25”, for a slight grade down from the rear. The well lips just hide the tops of the tires. F is 225/50/17 R is 255/50/17.
I’m thinking incorrect indexing is the most likely. The torsion bars were removed and reinstalled about 20 years ago at a shop, but frankly I don’t remember if that’s when I first noticed the issue or not. The only worn parts left to be considered for replacement are the torsion bars themselves. They are the 778 and 779 for the originally 383 car (440 now). 0.90 diameter. Correct sides.
Don’t like the bump stop being sandwiched. Limits the travel on one side.
May as well replace the bars. The current bars are 50 years old and prob not like being twisted to correct install. Likely some metal fatigue. I like the way the car rides currently, but wouldn’t mind a little stiffer. No potholes or rough roads where I cruise. Planning for the PST version - 20 degree clocking: 1.03" Torsion Bar Deluxe Kit - Polygraphite - B & E Body. Other than being a little lighter in the wallet, I don’t think I’ll be any worse off with new bars, that’s for sure.
Re: Torsion Bar Adjuster / Bump Stop [Re: BadFishy] #2998100
12/24/21 01:51 AM
12/24/21 01:51 AM
AndyF Offline
AndyF  Offline
Could be several different things. Put the car up on the lift and pull the bars out and check it out. You're more likely to find the problem by looking at the parts. I doubt the bars are indexed wrong, probably just a weak bar.
Re: Torsion Bar Adjuster / Bump Stop [Re: BadFishy] #2998124
12/24/21 08:48 AM
12/24/21 08:48 AM
Minn
SportF Offline
SportF  Offline
Minn
Gang, I've played around with a lot of different bars, but I don't think you could be off on the hex. That is 60 degrees and would probably show up on the adjust bolt at like two inches. I would like to hear from somebody to see if it has actually happened because in my experience you would never have enough adjustment to even bring the lower arm off the rubber stop.
Re: Torsion Bar Adjuster / Bump Stop [Re: SportF] #2998138
12/24/21 09:50 AM
12/24/21 09:50 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
This ^
Can't be indexed wrong.
Re: Torsion Bar Adjuster / Bump Stop [Re: ruderunner] #2998146
12/24/21 10:08 AM
12/24/21 10:08 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
When you check the ride height it isn't just "measure to the floor". It's the differential measurement between basically the LCA bushing and the lower ball joint. There is a photo in the FSM that shows the locations.
Re: Torsion Bar Adjuster / Bump Stop [Re: BadFishy] #2998155
12/24/21 10:50 AM
12/24/21 10:50 AM
IMGTX Offline
IMGTX  Offline
Start at the basics.
Without anyone in the car at first. (Some people align a car with driver weight in the seat and that is fine but not for diagnostics.)
Put it on a flat level floor. Measure from the ball joint on each side to the ground and from the bottom edge of the LCA hex socket to the floor. The difference is the adjustment height. Should be about 1-1/8" if stock.
If it is not a significant difference between sides, and you have bumper distance/space issue, then you have issues with the bumpers not matching, or a bent arm or chasis etc.
If you even out the height, and the bumper issue goes away but the bolt is excessively different, You have torsion bar issues. 2 bars of the same side in the car, old & saggy bars, bars on the wrong side, indexed incorrectly, etc.
Some people will say that you can't index them wrong etc,, and they are correct in a perfect world, but I have seen many things that a mechanic should not be able to do, be done by bad mechanics. Never underestimate the ability of a bad mechanic to achieve unachievable heights or depths in stupidity. laugh2 I know this because when I was younger and learning I did a lot of stupid stuff you shouldn't be able to do to a car. I did them quite well too. laugh
Re: Torsion Bar Adjuster / Bump Stop [Re: IMGTX] #2998192
12/24/21 12:47 PM
12/24/21 12:47 PM
moparx Offline
moparx  Offline
HEY ! i'm old and STILL do stupid stuff ! panic laugh2
beer
Re: Torsion Bar Adjuster / Bump Stop [Re: SportF] #2998204
12/24/21 01:14 PM
12/24/21 01:14 PM
AndyF Offline
AndyF  Offline
Yeah I agree. I'd have to see a video of someone installing a torsion bar off one hex before I believed it. I don't think there is enough travel in the lower control arm to be off one flat. If you switch bars side for side then that is half a hex and even that is tough to do. I tried to install bars on the wrong side once but could not do it due to lack of travel. I've heard of people having the bars on the wrong side so perhaps it can be done but it messes up the adjustment for sure. One of the torsion bar suppliers hired me a few years back to help them sort out a hex offset issue. As the torsion bars get bigger, the offset has to be carefully calculated or else the adjuster won't have the correct travel. The position of the hex needs to be held within a few degrees for the adjuster to work correctly so there is no way a big bar can be off by a flat or even a half flat.
Re: Torsion Bar Adjuster / Bump Stop [Re: AndyF] #2998208
12/24/21 01:29 PM
12/24/21 01:29 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yea, with big bars you don’t have that error margin.
I agree it’s pretty tough to mess up with a stock bar. And the adjuster would be way in or way out and the ride height would be real low or high. I’ve see a car with the adjuster bolt completely out and the adjuster arm just sitting on the pad/nut.
Either way, a hex issue it not going to fix his static bump stop to frame clearance. That is purely a function of ride height and tire height. So the OP needs to change one of those OR just put in a shorter bump stop.
Most people set the ride height to the look they want. Typically that look is the body relative to the ground and/or tire. And then match that height side to side.
Here’s a short bump stop you can buy and move on with your life.
https://www.amazon.com/Energy-Suspe...&hvtargid=pla-569060105739&psc=1
Re: Torsion Bar Adjuster / Bump Stop [Re: autoxcuda] #2998224
12/24/21 02:58 PM
12/24/21 02:58 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Check the sleeve in the k-frame where the lower arm shaft goes through. Maybe have issues with the weld or it cracked, both allowing it to spin.
Carl Kessel
Re: Torsion Bar Adjuster / Bump Stop [Re: CKessel] #2998287
12/24/21 09:57 PM
12/24/21 09:57 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This discussion reminds me that back in 1957 when, I guess, Chrysler's torsion bar front suspension was first introduced, there was a dealer's Plymouth running around town with only one front wheel, an obvious publicity and promotion stunt to get gawkers and generate new car sales. I saw the car with my own eyes making a turn at an intersection.
Back then, the fall introduction of new car models was a very, very big deal.
Somebody needs to copy this feat and post photos of the car turning a corner. popcorn
Re: Torsion Bar Adjuster / Bump Stop [Re: kentj340] #2998293
12/24/21 10:53 PM
12/24/21 10:53 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Originally Posted by kentj340
This discussion reminds me that back in 1957 when, I guess, Chrysler's torsion bar front suspension was first introduced, there was a dealer's Plymouth running around town with only one front wheel, an obvious publicity and promotion stunt to get gawkers. I saw the car with my own eyes making a turn at an intersection.
Somebody needs to copy this and post photos of the car turning a corner. popcorn
Re: Torsion Bar Adjuster / Bump Stop [Re: bobby66] #3012753
02/06/22 02:32 PM
02/06/22 02:32 PM
nj
MoJoe Offline
MoJoe  Offline
nj
I had a similar problem after replacing my rear shocks and wanted to bring the front end up, which I did, and everything seemed ok. After a few trips something didn't seem right which I attributed to a slow leak on the drivers side tire, although a little inconvenient I fill it to the proper inflation and go on my way, I'm getting new tires soon but am not really ready yet. Any how, even after inflating the tire the driver side seem lower and upon investigating the situation it was close to 3/4" difference after measuring on a reasonably level surface. I got setup and started to crank up the adjustment bolt and slowly started to get it to match the other side and jostled it like suggested and it seemed to settle about a 1/4" or so I cranked it up a few more turn when..."oh no" the wrench gave way and the adjustment bolt came out. A couple years back I had rebuilt the front end when I converted to front disc brakes. I replaced the bushings and pivots, but not the adjusters as they seemed to be ok, needless to say this one was not and stripped. I don't know if you got yours straighted out, but it could be something to consider. I looked into getting some new one and they are pretty pricey, being a good Mopar guy I ha some extra lower control arm laying around and was able to replace it and get back on the road
