Re: E body Inspection questions... [Re: topside] #2997978
12/23/21 06:37 PM
12/23/21 06:37 PM
California
BigDaddy440 Offline OP
California
Originally Posted by topside
Quick fix for a rattle between the inner & outer panels maybe ?
Very well could be. The metal inserts are identical on both sides which is what made me think it was purposeful from the factory.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: E body Inspection questions... [Re: second 70] #2997980
12/23/21 06:44 PM
12/23/21 06:44 PM
California
California
Originally Posted by second 70
Those holes by the leaf spring are not on my Feb. 70 383 Cuda but since the AARA didn't start production until March that could explain them missing.
Interesting and makes sense that they wouldn't be on early (FEB) cars prior to the AAR cars being planned or built.
Still interested to know if only 340 cars had this advantageous "Weight Reduction" smile
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: E body Inspection questions... [Re: BigDaddy440] #2998026
12/23/21 09:33 PM
12/23/21 09:33 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Quote
Is this pattern of holes near the leaf hanger standard from the factory?
My 5/70 LA built challenger has the same holes. (318, deputy)
Yeah, it's hopped up to over 160...
Re: E body Inspection questions... [Re: jt4406] #2998078
12/23/21 10:46 PM
12/23/21 10:46 PM
California
California
Alright..looks like it's date related and not sub model related.
Thanks for the info!
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: E body Inspection questions... [Re: BigDaddy440] #2998154
12/24/21 10:44 AM
12/24/21 10:44 AM
God's Country Maryland
GODSCOUNTRY340 Online content
GODSCOUNTRY340  Online Content
The piece in the trunk is a welder's trick to "fill weld" the hole in the lid. The quicker you fill the hole the less heat produced, less heat equals less warping.
Re: E body Inspection questions... [Re: GODSCOUNTRY340] #2998241
12/24/21 05:05 PM
12/24/21 05:05 PM
California
California
I can understand that as a technique but I don't know what hole would be welded in this case.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: E body Inspection questions... [Re: BigDaddy440] #2998255
12/24/21 05:58 PM
12/24/21 05:58 PM
There's a hole in the inner structure so it would be safe to say there was a hole drilled in the outer side as well.
Re: E body Inspection questions... [Re: BigDaddy440] #2998260
12/24/21 06:37 PM
12/24/21 06:37 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
are you sure that there are only the 2 holes - look for additional holes work not much would be mounted with just 2 shruggy
Re: E body Inspection questions... [Re: 6bblgt] #2998264
12/24/21 07:04 PM
12/24/21 07:04 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
Our 71 Barracuda has the holes in the inner rocker like the OP asked about.
Re: E body Inspection questions... [Re: 6bblgt] #2998296
12/24/21 11:19 PM
12/24/21 11:19 PM
n.c.
geo. Offline
geo.  Offline
n.c.
Originally Posted by 6bblgt
the holes on the inner rocker panels are where the side exhaust "megaphone" hangers are mounted on AARs
the holes on the fenders are probably from rivet on aftermarket body side mouldings - if the doors & quarters don't have the same holes, the fenders were sourced from another Barracuda at some point
Yes, on AARs and T/As there are nuts welded behind some of the holes, not all.
And I think many '71 E bodies have the holes, a friends green/198/fixed window car had them.
I guess the Trans Am package hadn't been cancelled yet, really wish they'd built some!
