Shortest rods?
#2997670
12/22/21 07:41 PM
12/22/21 07:41 PM
Posts: 9,444 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The only reason to consider this is to use some valuable parts in a new application. I am going to use the crank and intake from the 550 megablock motor in a new BMP Aluminum block. So what I want to do with the heads, valvetrain , pistons, rings and block left over from previous build is to put a stroker crank in it and lower the compression to a liveable level for the 440-1 heads. My Cp pistons have a pin height of 1.662. To get compression down to 11/1 with all this I would need to run a 6.700 rod on a 4.5 crank a friend has for sale. That ends up at 1.4888 rod ratio. Not too terrible, but there is also a 4.75 crank available which would need a 6.535 rod, which is 1.37. since this motor will be aimed at a power band of under 6500 rpm, maybe even below 6,000 rpm side loading will be somewhat less than a 7500 rpm race motor. So let's hear what you think. By being able to reuse the original heads, pistons, rings, and block the cost of this build would be pretty low. And the 4.75" crank would make good use of the fully ported -1 heads I have also, and at low rpm
8.77 153 mph best, 3055 lbs 528 indy 440-1 alky
Re: Shortest rods?
[Re: gregsdart]
#2997678
12/22/21 08:31 PM
12/22/21 08:31 PM
Posts: 620 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I think that you may have counter weight clearance issues with a 6.53 rod and a 4.75 crank.
Joe
Without Data, you’re just another guy with an opinion.
Re: Shortest rods?
[Re: gregsdart]
#2997746
12/23/21 12:55 AM
12/23/21 12:55 AM
Posts: 29,672 Oregon
AndyF
Joe Maybe, Not sure how to do the math. You can't do the math unless you know the size of the counterweights as well as the shape of the piston skirts. Most likely you'll need to mock it up. I'm pretty sure it won't work but if you have the parts sitting on the bench it will only take a couple of minutes to swing a piston and rod on the crank to see for sure.
Re: Shortest rods?
[Re: AndyF]
#2997754
12/23/21 01:15 AM
12/23/21 01:15 AM
gregsdart
Looks like the longest stroke I could use would be a 4.5 with those pistoñs. I figured longer might add value since the cranks would all cost the same. But after penciling it out adding stroke eats up clearance in a hurry.
Re: Shortest rods?
[Re: gregsdart]
#2997893
12/23/21 02:36 PM
12/23/21 02:36 PM
Posts: 16,644 Western NC
440Jim
Western NC
I made a quick change to an old calc I did years ago on a low deck idea. I haven't double checked it yet. But is this what you are looking for? The distance under the piston pin can be a tight spot hitting the crank counter weight.
1993 Daytona, 1973 Cuda 440, 2009 Challenger 5.7 Hemi, 2015 RAM 1500 5.7 Hemi 8-speed auto, Link to 572 B1 - Part 1
