Re: Rattle can or automotive paint for engine??
[Re: 6PakBee]
#2997018
12/20/21 12:29 PM
12/20/21 12:29 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Any chance of getting the paint codes you use or is it one of those "if you look it's obvious" kind of thing. For my Street Hemi Orange I had them mix up EV2 without the yellow metallic.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2997057
12/20/21 02:23 PM
12/20/21 02:23 PM
Posts: 10,130 A Red State
SNK-EYZ
A Red State
Any chance of getting the paint codes you use or is it one of those "if you look it's obvious" kind of thing. For my Street Hemi Orange I had them mix up EV2 without the yellow metallic. That's exactly what I use in urethane, with or without flattening agent added.
[Re: moparmarks]
#2997062
12/20/21 02:29 PM
12/20/21 02:29 PM
Posts: 4,924 Tri-Cities, Washington
VITC_GTX
Any chance of getting the paint codes you use or is it one of those "if you look it's obvious" kind of thing. For my Street Hemi Orange I had them mix up EV2 without the yellow metallic. Great information. Thanks for sharing!!!
[Re: moparmarks]
#2997249
12/21/21 10:23 AM
12/21/21 10:23 AM
Posts: 10,707 North Dakota
6PakBee
North Dakota
Any chance of getting the paint codes you use or is it one of those "if you look it's obvious" kind of thing. For my Street Hemi Orange I had them mix up EV2 without the yellow metallic. Thanks! If you have any more, keep them coming.
[Re: 6PakBee]
#2997256
12/21/21 11:01 AM
12/21/21 11:01 AM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
MP Turquoise on the 440....
PPG 3116 enamel without catalyst on the low deck/raw aluminum heads
PPG Shopline 3116 Single stage catalyzed Urethane on the Hemi
3116 was recommended by Steve Dulcich circa 2001, later on I found out it was the exact formula MP used on crate engines for many years.
TBH I preferred the coverage of the old enamel the PPG store doesn't want to sell anymore, and will give the Hemi one more coat + will probably clear coat it with some kind of high solids clear.
When I run out of 3116 I'm probably going to generic/industrial Omaha Orange as used on various municipal truck applications and so on as it's more easily obtained in enamel and will use a catalyst.....
They all have their ups and downs, it seems I can more easily get a thin, slightly dull OE looking finish with spray cans than I can with a gun and higher quality paint, but the higher quality paint lasts longer and looks much better.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2997310
12/21/21 02:07 PM
12/21/21 02:07 PM
Posts: 245 Falcon, CO
Mad-Max
Falcon, CO
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Oxx" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler' 52 Willys M-38 "Poncho"
[Re: maximus]
#2997819
12/23/21 10:54 AM
12/23/21 10:54 AM
Posts: 9,827 MI, usa
dvw
MI, usa
All mine are single stage urethane out of a gun. Have some that have been painted nearly 20 years and look new. Just did my race car block and heads. The small block was done in 2003 Doug
[Re: dvw]
#2997830
12/23/21 11:28 AM
12/23/21 11:28 AM
Posts: 4,564 Motor City
6PKRTSE
Motor City
All my engines are painted with Dupicolor Hemi orange engine enamel. I hit them with light coat of self etching primer first. Then spray orange. No complaints. My Charger 440 Six Pack engine has been in since 2007 and the Challenger Hemi since since 2017. Roached Runner 383 engine is no installed also.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2998169
12/24/21 11:41 AM
12/24/21 11:41 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Great subject and Happy Christmas. I only see one engine paint available for us Limeys! VHT enamel. I always put it straight to metal, and a lifetime later I find they have hi temp primer... It also says “cure at 200 degrees for twenty minutes or run engine” That would explain why it never lasted lol...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: Gtxxjon]
#2998226
12/24/21 03:10 PM
12/24/21 03:10 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I’ve always used duplicolor engine enamel.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: mopardude318]
#2998271
12/24/21 07:44 PM
12/24/21 07:44 PM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
Where did you get that B&M super charger?
Abe Lincoln
[Re: dart4forte]
#2998282
12/24/21 09:26 PM
12/24/21 09:26 PM
mopardude318
Gilroy,CA.
Where did you get that B&M super charger? I found that 8 years ago on Craig’s list NOS complete, B&M cast the manifold. I will be going with a 671 in the summer time. This little 162 runs out of steam on my 408.
[Re: mopardude318]
#2998300
12/24/21 11:55 PM
12/24/21 11:55 PM
Posts: 35 Livonia,MI
1968fury
Livonia,MI
Bill hirsch paint is amazing. gas resistant I've sprayed it or used a foam brush on cast iron.
71 scamp 340 509 cam 456 gear,68 fury1 318 3spd on the tree,50 merc flathead 3x2 3spd w/overdrive
[Re: 1968fury]
#2998304
12/25/21 12:46 AM
12/25/21 12:46 AM
dvw
MI, usa
You don’t need high temp paint. Normal car urethane will standup to anything. You can even bondo up parts to make them smooth. Notice the missing Indy logo on the head and valve cover. No pits in the intake. Yup it’s bondo, 9 years and counting. Doug
