Re: Removing "cat" from older car?
[Re: Faust]
#2992904
12/07/21 02:47 PM
12/07/21 02:47 PM
Posts: 3,758 Canada -- Posts: 4034 -Registe...
5thAve
Technically emissions equipment is federal and it's illegal to mess with. But my excuse to remove it would be it's bad and the part is no longer available,
Unless it's clogged it won't make much if any improvement removing it. The lack of performance is because of the 4.1. That's one of the reasons the earlier models of those Cadillacs are the ones people want even the ones with the 8-6-4.
[Re: 5thAve]
#2993590
12/09/21 01:04 PM
12/09/21 01:04 PM
Posts: 1,957 Massachusetts
Faust
Massachusetts
Unless it's clogged it won't make much if any improvement removing it. The lack of performance is because of the 4.1. That's one of the reasons the earlier models of those Cadillacs are the ones people want even the ones with the 8-6-4. I understand the problem. Long term solution is a swap to an LS4.
[Re: Faust]
#2995735
12/16/21 09:24 AM
12/16/21 09:24 AM
Posts: 14,249 RI Deep in the rust belt
chargervert
I usually put them in one of those cat caddies, and remove the feline from the car. Just drive the 64 Plymouth instead!
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: chargervert]
#2997030
12/20/21 01:17 PM
12/20/21 01:17 PM
chargervert
Did you ever get the cat out of the car,it's getting pretty cold out there these days! It was 14 degrees in Attleboro this morning!
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: ZIPPY]
#2997528
12/22/21 10:29 AM
12/22/21 10:29 AM
chargervert
What more can you ask for than some pussy and a tunnel ram dual quad intake manifold for a Hemi!
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: Pacnorthcuda]
#2997673
12/22/21 07:58 PM
12/22/21 07:58 PM
Posts: 17,088 S.E. Michigan
ZIPPY
S.E. Michigan
Jeez....Post an innocent cat picture and the Perv comments start flying...
Rich H.
[Re: ZIPPY]
#2997780
12/23/21 07:49 AM
12/23/21 07:49 AM
Posts: 4,167 ohio
ruderunner
ohio
I'm thinking the cat weighs more than a Hemi
Angry white guy
