Shortest rods? #2997670
12/22/21 07:41 PM
12/22/21 07:41 PM
gregsdart Offline OP
The only reason to consider this is to use some valuable parts in a new application.
I am going to use the crank and intake from the 550 megablock motor in a new BMP Aluminum block.
So what I want to do with the heads, valvetrain , pistons, rings and block left over from previous build is to put a stroker crank in it and lower the compression to a liveable level for the 440-1 heads. My Cp pistons have a pin height of 1.662.
To get compression down to 11/1 with all this I would need to run a 6.700 rod on a 4.5 crank a friend has for sale. That ends up at 1.4888 rod ratio. Not too terrible, but there is also a 4.75 crank available which would need a 6.535 rod, which is 1.37. since this motor will be aimed at a power band of under 6500 rpm, maybe even below 6,000 rpm side loading will be somewhat less than a 7500 rpm race motor.
So let's hear what you think. By being able to reuse the original heads, pistons, rings, and block the cost of this build would be pretty low. And the 4.75" crank would make good use of the fully ported -1 heads I have also, and at low rpm
Re: Shortest rods? [Re: gregsdart] #2997678
12/22/21 08:31 PM
12/22/21 08:31 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I think that you may have counter weight clearance issues with a 6.53 rod and a 4.75 crank.
Joe
Without Data, you’re just another guy with an opinion.
Re: Shortest rods? [Re: sr4440] #2997701
12/22/21 10:37 PM
12/22/21 10:37 PM
Joe
Maybe, Not sure how to do the math.
Re: Shortest rods? [Re: gregsdart] #2997746
12/23/21 12:55 AM
12/23/21 12:55 AM
AndyF Offline
AndyF  Offline
Joe
You can't do the math unless you know the size of the counterweights as well as the shape of the piston skirts. Most likely you'll need to mock it up. I'm pretty sure it won't work but if you have the parts sitting on the bench it will only take a couple of minutes to swing a piston and rod on the crank to see for sure.
Re: Shortest rods? [Re: AndyF] #2997754
12/23/21 01:15 AM
12/23/21 01:15 AM
Looks like the longest stroke I could use would be a 4.5 with those pistoñs. I figured longer might add value since the cranks would all cost the same. But after penciling it out adding stroke eats up clearance in a hurry.
Re: Shortest rods? [Re: gregsdart] #2997821
12/23/21 10:56 AM
12/23/21 10:56 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
You mentioned rod stroke ratio so you understand the concept. I like the longest rod I can stuff in the engine, will not see a performance increase, but the longevity is what I am after. My last engine is a 4.25 stroke 4.5 bore with a 7 inch chevy rod, it makes tons of torque, and just over 800HP and revs to 7000 like a smallblock. very happy with the combination.
Re: Shortest rods? [Re: gregsdart] #2997893
12/23/21 02:36 PM
12/23/21 02:36 PM
NC
440Jim Online work
440Jim  Online Work
NC
I made a quick change to an old calc I did years ago on a low deck idea. I haven't double checked it yet.
But is this what you are looking for?
The distance under the piston pin can be a tight spot hitting the crank counter weight.
Re: Shortest rods? [Re: 440Jim] #2997916
12/23/21 03:59 PM
12/23/21 03:59 PM
Jim, I wasn't far off on my assumptions. Rod c/cc - 1/2 stroke , - .495 (1/2 pin dia, - .190,- .060 clearance= Max radius of crank cw.
Re: Shortest rods? [Re: gregsdart] #2997959
12/23/21 05:52 PM
12/23/21 05:52 PM
NC
440Jim Online work
440Jim  Online Work
NC
As Andy mentioned, if the piston skirt is not well designed for this application, it could hit the counterweight before the piston pin boss.
My new B1 pistons are 0.205" below the pin, maybe for more strength then those 0.190 ones I had back then. And these B1 pistons are designed for 7.100" rods, 4.500" stroke, so there is plenty of room.
