1971 E body Clutch pedal help. #2997633
12/22/21 04:33 PM
12/22/21 04:33 PM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
Hi I am wondering if anyone has pictures of 1971 Clutch pedals for a Challenger. I want to do an Automatic to manual swap and want to get the correct pedals. I have heard there are differences in the pedal design for different years. I posted a picture of some pedals that are for sale that are suppose to be correct for a 71 Challenger. Would anyone know if they are correct for my year?
Thanks for any responses.
Re: 1971 E body Clutch pedal help. [Re: batt2rm] #2997635
12/22/21 04:40 PM
12/22/21 04:40 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
looks like someone bent that brake pedal.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1971 E body Clutch pedal help. [Re: moparmarks] #2997688
12/22/21 09:21 PM
12/22/21 09:21 PM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
Wow, good eye on the bent brake pedal I did not notice it until you mentioned that.
Re: 1971 E body Clutch pedal help. [Re: moparmarks] #2997689
12/22/21 09:22 PM
12/22/21 09:22 PM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
Thanks for the pictures!
Re: 1971 E body Clutch pedal help. [Re: batt2rm] #2997760
12/23/21 01:58 AM
12/23/21 01:58 AM
IMGTX Offline
IMGTX  Offline
There is supposed to be an over center spring on the clutch pedal. If you run the factory style pressure plate you will need it. If you run an aftermarket Diaphragm clutch it isn't needed.
It is something to be aware of if you are looking to buy the whole setup.
Re: 1971 E body Clutch pedal help. [Re: batt2rm] #2997800
12/23/21 09:26 AM
12/23/21 09:26 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
[s][/s]Looks like modified 68-9 B body pedals in an E body pedal box to me.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
